Old 01-07-12, 02:48 PM   #1
Scoobs
Vipers Pillion Bitch
Scoobs's Avatar
Default Question about USD forks
One of the upper tubes on my forks has got a bit of a scuff in it. It's only cosmetic but it bugs me. I just want to spin the upper so that the damage can't be seen. Is it just a case of loosening the pinch bolts on the triple clamps and spinning the upper? I can't get the front off the ground so there is no weight on the fork springs. Does this matter too much, or will loosening the pinch bolts cause a twist?
Thanks for the advice.
I look good, I mean really good! Hey everyone come and see how good I look!
Scoobs is offline   Reply With Quote
Old 01-07-12, 04:39 PM   #2
BillyC
BillyC's Avatar
Scoobs, yes you can turn the fork leg while it's still in the clamp - but you must get the weight off the front end first.
Loosening the clamps without lifting the front will give a high risk of that fork rising through the clamp and yoke... Getting it down again will be more hassle than it's worth!
Be sure to note top clearance of the dork leg through the tip clamp, and ensure you re-torque the clamp bolts.
Old 01-07-12, 07:45 PM   #3
Default Re: Question about USD forks
Originally Posted by BillyC View Post
dork leg
Ha ha!
Old 02-07-12, 11:05 AM   #4
jambo
jambo's Avatar
As above, weight off the front wheel, loosen the upper & lower fork clamps (plus usually the clip-on for that side) and you should be able to rotate the fork outer to the point you want it. Do up the bolts again to the correct torque, and you're away.
Jambo
Old 02-07-12, 04:33 PM   #5
Scoobs
Scoobs's Avatar
Nice one gents.
I'm hoping the dork leg was a genuine typo
Old 02-07-12, 05:08 PM   #6
davepreston
and dont introduce the forks to a bandit
Old 03-07-12, 06:42 AM   #7
BillyC
BillyC's Avatar
You should've seen what happened when I tried to type in "Scoobs"... What the iPhone autocorrect suggested was unrepeatable.
Old 03-07-12, 05:16 PM   #8
Scoobs
Scoobs's Avatar
Another reason why I wish I had an iPhone. Just to try that out.
Old 03-07-12, 05:17 PM   #9
Scoobs
Scoobs's Avatar
F*** **f Preston
Bandit 600 forks question Stonesie Bikes - Talk & Issues 3 05-04-11 05:19 PM
USD GSXR1000 k1 forks | standed forks - curvy Nicky S SV Talk, Tuning & Tweaking 113 07-09-09 01:12 PM
Wheels/forks compatability question rowdy SV Talk, Tuning & Tweaking 2 21-03-09 02:07 PM
Gen 1 w/zx6 shock, 05 GSXR forks, notes & question JuicyGuzzi SV Talk, Tuning & Tweaking 14 10-10-07 09:43 PM
Forks question WicklowSV SV Talk, Tuning & Tweaking 2 17-03-05 02:09 PM
