11-09-17, 02:03 PM | #1 |
Where can I find fairing mount??
The piece of hardware used to mount the fairing shown in the links got bent in a crash... Trying to figure out what the part is called or where I can buy it thanks!!
https://ibb.co/kdpjWv |
11-09-17, 02:21 PM | #2 |
Re: Where can I find fairing mount??
it's not identical, but R&G do a crash bung & mount that's designed to replace it. Not a cheap solution but at least one that's available.
Silver SV650SK3, Fuel exhaust |
11-09-17, 02:54 PM | #3 |
they are not available separate only in a kit which IIR is £180.
TBH the bracket is not bad and a tap with a hammer should straighten it out enough to be useable. if it cracks at the weld which it usually does then just straighten it and take to your local welder. |
11-09-17, 03:14 PM | #4 |
http://www.rg-racing.com/browsebike/...L/#prettyPhoto
£85 + VAT & delivery but definitely not cheap.
11-09-17, 11:28 PM | #5 |
The Sick Man
stock bracket is a pile of poo
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
13-09-17, 07:12 AM | #6 |
I did exactly the same it's really simple and quick for a welder to fix so go that route
Sent from my SM-G935F using Tapatalk |
21-09-17, 09:12 AM | #7 |
Make sue you get it welded if you're going to ride the bike without the faring, I ended up losing mine so had to get another made up.
I used the other side as guidance to get the end bits machined at work and had them connected by a piece of straight steel bar as opposed to a curved tube. It isn't the prettiest thing but it doesn't matter since it's hidden by the fairing. |
Thread Tools | |
Lower Fairing J-Mount Bracket Thing & Fairing Repair | SixFiddy | SV Talk, Tuning & Tweaking | 10 | 29-04-17 09:12 PM |
Sv650s fairing mount kit. Help needed | Bobbydazzer31 | Stuff Wanted | 4 | 18-02-13 09:33 PM |
Help!!....sv650s fairing mount needed!! | jonnysv650s | Stuff Wanted | 4 | 05-01-13 12:52 PM |
Anyone know where I could find a tax disc sticker to mount the disc on bodywork? | Horney | SV Talk, Tuning & Tweaking | 8 | 14-01-08 08:38 AM |
Fairing Mount Indicators | Tris | SV Talk, Tuning & Tweaking | 4 | 24-05-06 10:44 AM |
