16-10-22, 12:15 PM | #1 |
Floppy clutch lever?
Taking a break from banging my head against wall so thought i'd ask the cleverer people if they have any info on this...
SV650N 99 won't keep clutch adjustment.. Clutch plates, steels and cable all new 500 miles 'ish and worked well until now. New oil today also and at correct level. 1#Lever end loose floppy (f'nar) so do full correct adjustment as per bibs and sids clutch mantra guide. Cable both ends and wormdrive set and perfect. Put bike in 1st lovely, ride forward a bit, nice then flick beautifully into neutral. 2#Let clutch lever out then pull back in put into 1st and clunk bike trying to pull away with clutch fully pulled in and having to hold it back with front brake and no chance of getting neutral with engine running. Wtf? Roll bike back to garage re-adjust cable wormdrive yadda yadda yadda everything locked down and perfect and repeat 1# and 2# until you start banging your head on wall... Anybody got any ideas? As usual i'm pulled in 75 dirrections so if i don't get back to any reply for a bit thats why, not because i think you're an ....
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. Last edited by Geodude; 16-10-22 at 02:35 PM. Reason: Brain hurts |
16-10-22, 12:27 PM | #2 |
Re: Floppy clutch lever?
Ps i haven't pulled the clutch plates out yet to check if they are stuck together or whatever
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
16-10-22, 07:41 PM | #3 |
If you need to readjust so soon then something must be unadjusting itself. IE something is moving that shouldnt be.Lock nuts not locking or the worm drive is fubared allowing it to collapse a bit under load?
17-10-22, 06:25 AM | #4 |
Hmm worth a look as it sounds possible. How do i separate the worm drive to check its condition and ball count? Also, what size ball bearings if i find any missing?
17-10-22, 08:04 AM | #5 |
If it's at the point of needing ball bearings replacing Geo, it's time for a new worm drive.
17-10-22, 08:48 PM | #6 |
Is the cable moving freely enough? My old 99 always had an unpredictable clutch, not a lot but enough.
17-10-22, 08:48 PM | #7 |
Also Gary might be right, the worms last about 20k then they are pretty knackered
18-10-22, 05:44 AM | #8 |
I've ordered a new (overpriced) worm drive as i have no idea how many miles are on the old one fitted as i bought it second hand some time ago. Thanks for advice lads, appreciated as always. Will let you know when it arrives and is fitted.
Cable moving and routed right and when disconnected at each end i can move the inner easily with my (weak) fingers.
21-10-22, 12:32 PM | #9 | |
https://halnico.com/SV650/Clutch/SV650ClutchLifter.html HTH
23-10-22, 06:44 AM | #10 |
Thanks for the link very useful ta
Thread Tools | |
Gear lever and clutch lever wanted curvy | pauldogs | Stuff Wanted | 2 | 18-08-11 08:51 AM |
RH Footpeg Hanger, Rear Brake Lever and Clutch Lever for 2004 Naked Wanted | Drumming_Animal | Stuff Wanted | 0 | 26-07-10 10:52 PM |
Gear Selection Lever and Clutch Lever for K3 SV650S | xXBADGERXx | Stuff Wanted | 7 | 17-01-09 02:04 PM |
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. | Bayside GTR | Stuff Wanted | 0 | 29-10-07 11:24 PM |
2 left indicators + clutch lever + gear lever for pointy k6 | enduroman | Stuff Wanted | 3 | 06-09-07 09:26 PM |
