13-04-06, 07:26 PM | #1 |
Drilling Out Sump Plug?
Good folk of sv650.org, how is this done? Can it be done using a bog standard drill bit? I've managed to round the sump plug. It's royally fooked. I drilled right through the head and used an allen key to try to undo it, but to no avail. So now I'm left with a very round plug with a very big bloody hole through it. Is there any way of drilling it out? Or any other way I could try to undo it? I have a couple of bits that are meant to drill out rounded bolts but the tips are very flat so I don't know how they are meant to work
Any advice is very much appreciated!! |
13-04-06, 07:29 PM | #2 |
weld a nut the the plug and undo it with that.
13-04-06, 07:41 PM | #3 |
Sump plug
Hi there!
What we do if we get prob's like this on cars,is to either get some mole-grips on it,or if you've already drilled through it,and you have any Spline type tools,try and bash one up through the hole,and then undo it! I know this sounds like a real bodge,BUT Ford Ka's spark-plugs shear off in the cylinder head,and this is the only way to get the remains of the 'plug out without removing the Head! Good Luck! |
13-04-06, 08:30 PM | #4 |
13-04-06, 09:04 PM | #5 |
Try a set of plumbers pipe wrenches,always works on stubborn nuts for me
Blue naked K4 |
13-04-06, 09:33 PM | #6 |
you can get stud exstractors which you tap in and then use a spanner to undo also try lightly i mean lightly so as not to damage the threads tapping it with a hammer to loosen it first
14-04-06, 10:51 AM | #7 |
I wouldn't use an extractor, if there's anything left to grip, and with a rounded bolt head there is, then pipe grips or mole grips or similar is by far the best solution.
14-04-06, 01:57 PM | #8 |
Ok, thanks all. Will try the mole grips or pipe grips this weekend and see how I go. And if they don't work, I think I'll have to resort to this
14-04-06, 08:20 PM | #9 |
go buy an easy out!!!!!
opposite thread piece wind it in and it will wind it out! |
15-04-06, 01:32 AM | #10 |
Thread Tools | |
Sump plug washer - where from? | pencil shavings | SV Talk, Tuning & Tweaking | 26 | 17-03-09 08:52 PM |
Sump plug bolt | Jimbo_Bimbo | SV Talk, Tuning & Tweaking | 28 | 04-09-08 12:42 AM |
Sump Plug Torque? | skov | SV Talk, Tuning & Tweaking | 2 | 27-02-08 08:38 PM |
Sump plug washer | yorkie_chris | SV Talk, Tuning & Tweaking | 3 | 29-09-07 10:44 AM |
Pants! Sump plug... | localhost | Bikes - Talk & Issues | 12 | 20-01-06 11:27 AM |
