Old 31-08-12, 01:18 PM   #91
NTECUK
NTECUK's Avatar
Default Re: Help, I've screwed up the bottom shock bolt
Originally Posted by monkey View Post
Could there be washers missing from inside the dogbones?
Standard no washes .
But it would save a worlds of hert if you did .
Old 31-08-12, 02:46 PM   #92
Serdna
For my B1H into curvy shock swap i ordered the kwak bolt from my local mechanic/tuner. The bolt did not clear the dog bones so i cut it down so it was just long enough to get the nut on properly. It still did not clear the dogbones. So i think i spaced the dogbones out on the exhaust side with washers by 3mm. This meant that at worst case scenario in side to side play the smallest clearance will be 1mm. Ive been riding with that with no problem for 3 or 4000 miles.
Old 31-08-12, 02:47 PM   #93
hongman
Not sure how to interpret that - are you advocating putting washers in, or not?
My plan of attack is as follows:
1. Try new shorter bolt in the other way round
2. Stick a couple washers in (12mmx2mm)
3. Kwak Bolt / New Clevis from Nitron
Old 31-08-12, 02:48 PM   #94
hongman
Great, thanks!!
This is exactly what I am thinking about doing if the bolt doesnt fit the other way.
Old 31-08-12, 03:15 PM   #95
NTECUK
NTECUK's Avatar
Option 2.
Old 31-08-12, 06:53 PM   #96
hongman
Waheyyyyyyyyyyy
Option 2 it was.
I measured the distance between the clevis and the dog bone - both sides exactly the same. 12mm. So putting the bolt in the other way would have made no difference. I did it anyway to satisfy myself and strangely enough, it seemed to foul even more?
Banged on a couple M12 washers, and now I have about 1mm gap clearence
Took it for a quick razz round the block but kept it short as I had no gear on. Def no fouling, but still feels a bit stiff over a couple speed humps. Maybe need to fine tune the comp/rebound. Need to measure sag etc properly as well, but at least the ******* thing is on
Thanks all
Old 31-08-12, 07:07 PM   #97
NTECUK
NTECUK's Avatar
Originally Posted by hongman View Post
Waheyyyyyyyyyyy
Thanks all
Oh Matron
Well Sag needs adjusting then play with damping and rebound.
Take a nice route out and play away . when your happy remember to right it down in-case you change things when you go with luggage.
I did big adjustments with mine from the book and then cut what I felt best with in half's till it made no difference.
Ends up in slightly softer on re bound and higher compression,Thatis probably due to aging shock .
Oh who said too meany pie's
Old 31-08-12, 07:09 PM   #98
hongman
If I get a chance I'll take it for a whirl tomorrow, with the preload adjuster.
Any tips for setting sag when you are by yourself? lol
Old 31-08-12, 07:53 PM   #99
barwel1992
yeh, dont lol it will end bad
Old 31-08-12, 07:57 PM   #100
NTECUK
NTECUK's Avatar
Its best you do sag at home 35 mm full up . You need two people or 4 arms and a strong back
ZX9 or 10 bottom suspension bolt DaveW_42 Stuff Wanted 0 21-05-10 11:29 AM
what shock bolt ? barwel1992 SV Talk, Tuning & Tweaking 2 06-10-09 11:04 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
M10 55mm Shock bolt and nut for Kwak Shock Mr Speirs Stuff Wanted 3 24-10-08 12:00 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
