#91 |
#92 |
Tear it down, the carnage will be evident somewhere.
#93 |
Head first or shall I just rip cases apart?
#94 |
are you absolutely sure there's nothing elsewhere externally that is jammed etc first? Check around the clutch drive area and in the generator casing. If they are free to rotate then it can only be the crank or pistons.
Head gaskets arent cheap though so check before you remove. |
#95 |
All anciliaries and covers first too. Starter gear and everything you can get to.
Then head cover, cams, finally head.
#96 |
Just looking back at this post http://forums.sv650.org/showpost.php...6&postcount=64. Did you figure out what was going on there?
#97 |
Yeah, what happened was the starter cog thingy was jamming up against the casing everytime I was trying to turn the crank with a spanner (the starter motor was out), I just put the starter motor back in the keep the cog in place, that then freed up the crank a bit, and made it possible to get a full turn out of the crank. So now I am at the fact that I can only get a full turn at the generator side of the crank with a spanner.
#98 | |
#99 |
Yeah man, no probs, will be later from home as at work ATM.
#100 |
Wooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooo
![]() I have a free spinning engine ![]() ![]() Found a foreign piece of matter stuck in between the piston and valve, I couldn't understand why the piston wasn't returning, it seems this piece of metal wedged itself in somewhere, now everything is moving freely at the moment, I'm gonna do all the screws up on the head and turn the crank later just to be sure. Oh and BTW, Col, if you read this, it is not your fault ![]() ![]() ![]() ![]() ![]() |
help with uni project | TeddyBearKing | Idle Banter | 20 | 17-04-09 06:33 PM |
H*nd* project | DavieSV | Photos | 0 | 07-02-08 11:11 PM |
Londons Fastest Snail | scorpion | Bikes - Talk & Issues | 7 | 14-05-07 06:12 PM |
snail trails | poisonidea | Idle Banter | 16 | 07-01-07 11:21 AM |
What 'project' for £100 | glade | Bikes - Talk & Issues | 20 | 24-10-06 07:19 PM |
