Old 26-07-11, 10:22 AM   #91
Owenski
Default Re: Is this circuit going to work?
If there is anyone out there who has managed to maintain pace with the topic of this thread I've now completed my electrical adventure and this was the final method I used:
Turns out that once its all connected together up and running I realised that I've used far more connectors than necessary and also that my wiring was a little over kill. Mulitcore cable would have been a far better solution, as would have been sourcing some much better connectors than the ones I used. BUT we live and learn, it does at least all function as it should and I can leave skimming the fat from it until I can afford for the bike to be off the road for a while.
Old 26-07-11, 11:07 AM   #92
What connectors did you get
Old 26-07-11, 11:27 AM   #93
Owenski
HUUUUUUUUUUUGEEE ONES LOL, they were left over from sets I bought to do the reg/rec on the curvy. I'll see if I can find a link to similar ones...
Old 26-07-11, 11:30 AM   #94
Owenski
That was easy enough...
http://www.ebay.co.uk/itm/3-Pins-Wat...item2a1200a98a
I've now got this set in my watched items, if I do do the whole thing again I'll be doing it with these instead.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
Old 26-07-11, 11:33 AM   #95
ooooh they're good quality ones. I've got them on my HID's. Bit overkill for most things though
Have a look at this site. I got the mini-connectors 2.8mm. They have a kit of them for £46.50
http://www.vehicle-wiring-products.e...connectors.php
Old 26-07-11, 11:39 AM   #96
Owenski
other than a terminal block what methods or connectors are there available for splitting a cable 4 ways?
Each of my splitters is a blatent cop out method, the pos wire comes into a terminal block with hoops into each adjacent fixing screw then simply 4 wires out the other ends. oh and then blathered in insulation tape.
EDIT:
Never mind just saw this on the other page...
Old 26-07-11, 11:44 AM   #97
Solder and heat shrink?
Or one of these http://www.vehicle-wiring-products.e...connectors.php
Circuit Gearing chardy Mini-Twins 3 12-04-09 06:52 PM
regulating a circuit Wideboy Idle Banter 8 29-08-08 04:27 PM
Brands GP circuit Jdubya Track Days 2 12-06-07 02:52 PM
Crash.NET - Circuit-by-circuit with Dani Pedrosa. NewsBot News 0 04-04-07 04:10 PM
How do I check the charging circuit? thornton_chris SV Talk, Tuning & Tweaking 21 27-01-07 10:59 AM
