#991 |
If your,"Skid-Lid"
![]() is getting funky.Leave it upside down with a saucer of Bicarbonate of soda(Baking Powder) in it.It absorbs smells. Bi-Carb is also an effective fire extinguisher and can be used as a metal polish in paste form.Just add a little water to make a paste. HTH ![]()
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 13-03-17 at 02:19 PM. |
#992 |
This reminds me it's time to strip the lining out of mine and watch the water turn brown when I start washing it
#993 |
John T
Good tips. My new lid has a fully removable lining. That should make life much easier.
#994 |
Replaced the plastic rivets on my Curvy's small black plastic side-panels.One of the originals disintegrated when I removed the panel.
Couldn't find the right small sized ones so got these, http://www.ebay.co.uk/itm/10-SUZUKI-...YAAOxycmBSsfT~ ![]() and opened the holes in the fairing and small metal bracket using a 6.5mm drill.Had to use the drill to ream the hole a little as I didn't have a 6.6mm drill bit which would have been better. Much more substantial and easy to source.Nice solid fit ![]()
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 14-03-17 at 02:08 PM. |
#995 |
Took my Starter motor off and cleaned and serviced it.Little bit of Scotchbrite on the ends and some cheap silver aerosol paint(Quid from Poundshop).
Bared/Brightened all contacts/ring connectors and made sure starter to engine contact points were bare and no paint or grease.Dialectic grease over the ring contacts on the Starter after re-fit and also over the oil sender unit.Bolts reset with a little copper grease and a little locktite as they had been fitted using low impact White locktite.Only had blue so just a little dab. ![]()
#996 |
Copper grease AND high strength retainer?
#997 |
Copper grease on half of the bolts going into the block.Couple of dabs of Blue thread-lock on the bolt shaft nearer the bolt head.
White thread-lock=low impact Blue=Medium Red=High strength. Although thread-lock may not be needed it's just a small added precaution as these are low torque bolts.
#998 | |
John T
#999 |
John T
PC rebuild time. Hdd replaced with an ssd. Clean install of win 10. Machine transformed from a tortoise to a rabbit
Sent from my XT1032 using Tapatalk
#1000 | |
I've used ADATA drives.So far excellent.SSDlife reports I've got 6 years/5 months and 4 days left on the drive<BFG> ![]()
