Old 02-06-16, 09:46 PM   #991
johnnyrod
johnnyrod's Avatar
PS there's also 272256400320 I can't see the damage he's referring to though. It does come with a lens hood which you could sell and recoup the cost of the camera as the lens will be coated (and hopefully not eaten by fungus) so a hood isn't necessary. I spotted the PC connector for the flash on the front, like your other Contina, it did seem odd not to have one.
Old 03-06-16, 05:59 AM   #992
Kenzie
Kenzie's Avatar
Can see some paint chips and a couple of marks around the tri-pod socket but thats about it.
Old 03-06-16, 07:43 AM   #993
yokohama
291776924798 Lol. I put the bid on that one although I don't remember. It must have been after bank holiday wine. I expect the value to rise before the time's up though
Old 03-06-16, 07:44 AM   #994
johnnyrod
johnnyrod's Avatar
I've got a Contessa LK (viewfinder type) in a drawer, the rear element is pretty hazy but otherwise it's fine. I bought it to swap out the same in a Contessa LKE (rangefinder, E=entfernungmesser), and tried to get it clear again, but I think the surface is etched. The meter works, it's missing one tab off a ring, but otherwise is in good shape. I expect any 50mm f2.8 Tessar rear element would do, so if you see a busted camera around then you could have this one and swap out the rear glass, takes literally minutes. As it is now though the flare is too bad to be used, the rear element is the most important as it's nearest the film, I learned that the hard way.
Old 03-06-16, 10:53 AM   #995
Kenzie
Kenzie's Avatar
Will keep an eye out. Always on the prowl for cameras. Yokohama, the lenses arrived ok. Came back after a couple of days away and the Halina 35x, Hanimex 135 f2.8 and the two from you were waiting. It makes the MV1 look tiny
Sent from my Xperia T
Old 03-06-16, 11:26 AM   #996
yokohama
Nice to come back and open a bunch of new presents .
That's the thing with the smaller cameras like Olympuses OMs and later Pentaxes. They were fairly compact in size but the lenses at the time didn't follow suit. Balancing the OM10 with the chunky Vivitar on Monday took a bit of getting used to.
MV1 looks like a sexy little machine though.
Old 03-06-16, 05:07 PM   #997
Kenzie
Kenzie's Avatar
Its a very basic aperture priority camera so no option to change shutter speed apart from Auto, Flash X100 and bulb. Nice and light though.
You weren't joking were you Yoko, that Yashica Hanimex is a hell of a lump for something so small!
Old 03-06-16, 07:02 PM   #998
Kenzie
Kenzie's Avatar
Old 03-06-16, 08:07 PM   #999
yokohama
Hahaha. It certainly is. But confidence inspiring and solidly built all the same. It will withstand a few knocks.
So you're set up with the Minolta now. I've taken a few pics with the standard lens and it's nice and bright .... although I haven't seen the results yet.
Old 03-06-16, 08:22 PM   #1000
Kenzie
Kenzie's Avatar
No film loaded though. The lens seems like it has more glass than my OM lens. Got a bonus from work so may have to add to the collection. Also got another Halina 35, bit sticky on the focus/aperture rings but eases off with a bit of exercise.
