Old 19-03-17, 11:32 AM   #1001
Blapper
Blapper's Avatar
Default Re: What have you tinkered with today?
Putting the final touches to my '78 T140E before I sell her. Museum grade rebuild. *sigh*
Old 19-03-17, 06:49 PM   #1002
admin
John T
admin's Avatar
Spent most of a day trying to import a windows XP VDI file to Vitualbox. Gave up and created from scratch, a walk down memory lane looking at XP installation dialogue.
Old 20-03-17, 09:17 AM   #1003
tom_e
Done a couple of jobs on the SV at the weekend, one was replacing the rear pads. All done, nice and easy job jobbed.
Got in from a ride and noticed something splashed over the rear offside, on closer inspection it appears moving the res or possibly having a little too much fluid in there has caused the seal between the res and MC hose to spring a bit of a leak so I need to drain that and get a couple of winds of PTFE tape around it until I can get some new hose and do it properly.
I knew it had gone far too easily.
tom_e is offline   Reply With Quote
Old 20-03-17, 12:44 PM   #1004
garynortheast
garynortheast's Avatar
Managed to lock up the starter motor this morning. Just pulled it out, checked it over and put it back and we're away again.
Old 20-03-17, 02:41 PM   #1005
Blapper
Blapper's Avatar
How does that happen Gary?
Old 20-03-17, 03:40 PM   #1006
garynortheast
Started it and accidentally hit the kill switch. It must have managed to lock the starter gear against the ring and locked itself. Never happened before, and working perfectly now.
Old 20-03-17, 11:50 PM   #1007
Exuptoy
Not on the bike but I did dress the curb marks and strip the paint off my lads 17" Clio alloy wheels and threw some paint on them. They look ok for £50 inc tyres.
Old 21-03-17, 06:57 PM   #1008
Red Herring
Red Herring's Avatar
The gear change on my VFR. I run an upside down race pattern shift which is normally just a case of turning the crank on the gear shaft over, however the VFR doesn't have any linkage as the shift lever comes straight off the shaft as on a dirt bike. It's been bugging me for ages so today I finally got round to making a backing plate to sit behind the foot peg onto which I mounted a lever and then made up all the associated linkage. A proper raid of my parts bin using pieces from Suzuki, Yamaha and Honda! A proper result though so no more pulling up to the lights in 6th.......
Old 21-03-17, 08:22 PM   #1009
admin
John T
admin's Avatar
Red, photo please. I'd love to see it. Are you on the VFR Facebook group?
Old 21-03-17, 08:48 PM   #1010
Red Herring
Here you go
[IMG][/IMG]
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
