#1061 | |
![]() For anyone else looking to do headstock bearings, if you're in the south...gimme a shout, I have all the above and more. Would rather help and show you how to do it than read about you spending £xxx's on some spanner monkey doing it for you (and likely torquing things wrong, not giving a **** about your bike, etc)
93 VFR750 - WAY too many mods to list. Crashed ![]() 04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC |
#1062 |
Recently I've done the following:
Stripped down, cleaned and rebuilt and installed new calipers on my friends ER6N. Also installed an F4i master cylinder for him - he now has brakes! ![]() Balanced carbs for a friends VFR750 I'll be installing a new clutch cable and perch for the chap with an ER6N soon as well. He basically bought a bike from his cousin that was in an almost unbelievable state of disrepair. He needs his fork seals doing as well, I've never done it before and he needs the bike to commute, so I'm a bit hesitant to attempt it in a single day, I'd like a couple in case anything goes tits up. Doesn't look too difficult though tbf!
#1063 |
Fork seals are pretty easy, especially if RWU with no damping adjustment, as per the SV.
You will need a seal driver, dont try use anything else. I have a 43mm one you can borrow, it may work for slightly smaller forks. Easily done in a day, if nothing goes wrong and you have everything you need. If high mileage, you may have to change the bushes as well. For peace of mind use genuine oil seals, you can get away with aftermarket dust seals. Last edited by andy650; 18-08-17 at 05:37 PM. |
#1064 | |
Only cost me £100 ![]() Tinker: Garmin zumo cradle fitted and wired to one of Bibio's gadgets today and paired with headset/phone etc etc for music and directions. Last edited by Chris_SVS; 18-08-17 at 06:23 PM. |
#1065 |
Re set the spark plug gap within specs and bike rides like a different machine now
![]() Sent from my Pixel using Tapatalk |
#1066 | |
![]() nice to see you got a use for the gizmo ![]() |
#1067 | |
Haven't decided what accessory 3 is possibly grips |
#1068 | |
#1069 |
I now have a rack and Givi plate on my Bonnie. In the seven weeks I've owned the bike I've missed my topbox. It's a little large (V46) but it will do the job and it matches well colour wise.
We are the Goon Squad and we're coming to town, BEEP BEEP! |
#1070 |
Just had the two connector blocks apart in the front right of the fairing, black one and yellow one. The lcd on the instrument panel was not coming on and sometimes the speedo would fail to register for a short while after riding off. Cleaned all the connectors with an emery board, dowsed it in switch cleaner and then ACF50. Put them back together and now the lcd is really clear where it had been pretty dim before. Result!
https://teulu.bandcamp.com/releases Blue Curvy S with over 110,000 miles and still going strong. ![]() |
