05-09-09, 01:18 AM | #101 |
Re: USD GSXR1000 k1 forks | standed forks - curvy
busa and gixer ones are different, gixer ones are unique as they only came on (as far as i know) the K1-2 1000 which have 65mm mounting bolt spacings. although i can remember having a good look at a 1200 blandit and thinking 'those are the same callipers and discs as mine'.
05-09-09, 09:36 AM | #102 | |
These 6-pots also feature on the GSX1400, they are interchangeable with the (again better) 4-pots from the early K model GSXR's. |
05-09-09, 06:12 PM | #103 |
what is better about srad ones?
05-09-09, 06:17 PM | #104 |
k1-2 gsxr1000 are tokico aswell
06-09-09, 11:30 PM | #105 |
um iv been off the org for nearly 2 weeks and seems my thread is still going lol. um right so YC still thinks USD forks are chavy hehe i like them. but im a bit confused everone seems to think i should change the brakes so can people feel me in please btw i have not got any of the parts yet so i can steel change the set up. also if im changing this stuff will it still fit seeing as if i use the gixxer k1 brakes i might have to shave a bit off the mounts but apart from that it will fit fine also what will be the benefits of this if i was to change the set up ?
Curvy With Lots Of Bits ...
But Still More To Come Last edited by Nicky S; 06-09-09 at 11:31 PM. |
06-09-09, 11:40 PM | #106 |
As I put before, if you're discs are too wide then TL1000R discs are thinner and might save you shaving anything yet identical fitment / size to GSXR1000K1/2 / Hayabusa (plus a tadge lighter).
As an example I have at the moment GSXR1000K2 discs fitted to a TL1000R wheel fitted to hayabusa forks and calipers... Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
06-09-09, 11:44 PM | #107 |
what year TL would i use or dose it not matter also is it just the discs i would change or the calipers aswell ??
But Still More To Come |
07-09-09, 12:07 AM | #108 | |
The TLR discs are only 0.5mm thinner but if that avoids skimming the mounts it's worth it (plus lighter in weight), from memory they're 140quid each new from Suzuki. Oh yeah and don't forget that this only applies to OEM, EBC etc would give you an identical disc to GSXR1000/hayabusa, ie 5mm (wear limit 4.5mm) rather than 4.5mm (wear limit 4mm). Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F Last edited by fastdruid; 07-09-09 at 12:11 AM. |
07-09-09, 12:16 AM | #109 | |
So all in all i could just change the discs to TLR discs which would keep me from shaving the calipers mounts. i didnt know that the gixxer k1 calipers were 6 pots i thought they were 4. so i could use ether TLR or busa calipers ... but will these bolt onto the gixxer k1 USD forks ? also what year would the discs come from and would the calipers have to come from the same year or dose it not matter
But Still More To Come Last edited by Nicky S; 07-09-09 at 12:17 AM. |
07-09-09, 12:54 AM | #110 | ||
Again though seriously don't bother with the 6 pots, more grief than they're worth, go for the TLS or SRAD 4 pots although I'm not sure if there is any difference between them. Druid
curvy forks | husky03 | For Sale - SV's and SV related items | 5 | 29-10-08 07:10 PM |
Curvy forks wanted. | skapegoat | Stuff Wanted | 1 | 22-01-08 07:29 AM |
Gsxr Forks On Curvy | CHICKENSTRIPS | SV Talk, Tuning & Tweaking | 1 | 18-07-07 05:45 PM |
curvy sv forks fit k4 ??? | daddy_sperm | SV Talk, Tuning & Tweaking | 2 | 24-04-05 07:12 PM |
Conversion to GSXR1000 front forks ? | Powergaard | SV Talk, Tuning & Tweaking | 2 | 21-01-05 12:12 PM |
