Old 19-03-08, 02:20 PM   #101
21QUEST
21QUEST's Avatar
Default Re: I've got the front end Bug!! Help!!
They are about ?145 each new.
If you are running radials, I've got a set you can have in exchange for some notes .
Done naff all mileage and guaranteed to be straight, not grooved etc. Shoot us a PM if nterested.
Ben
Nemo me impune lacessit.
Old 21-03-08, 10:52 AM   #102
Rich
Rich's Avatar
Originally Posted by 21QUEST View Post
Looks excellent those . Any chance of a pic taken outside
Ben
Heres the pics you requested!!!
RIP Hovis - Unlucky Boyo
Old 21-03-08, 10:55 AM   #103
Cool!
Mine doesn't look anything like as blingy as that, but its nearly together
With a 120/70 SC1 supercorsa tyre too hehe.
A question for someone in the know...
SRAD spindle, which way should it fit in?
Old 21-03-08, 11:14 AM   #104
phil24_7
phil24_7's Avatar
Where's the pic??
Phil
I'm not here for a long time, I'm here for a good time!
Blue SV650 K3, GSX-R K5 front end, TL1000S clip-ons, lower fairings, seat cowl, gel seat, Pyramid undertray, R&G crash bungs, stainless steel bar ends, full titanium Akrapovic exhaust, Power Commander, clear rear light, flush mount front indys, mini rear indys, Autocom 300 duo intercom, Acumen cat 1 alarm and Micheline Pilot Power 2ct's.
phil24_7 is offline   Reply With Quote
Old 21-03-08, 11:23 AM   #105
Dangerous Dave
The sleeve should fit into the left hand fork leg...
and the axle bolt goes through from the right hand fork leg....
(Left and Right as you sit on the bike)
Old 21-03-08, 11:27 AM   #106
Old 21-03-08, 11:29 AM   #107
Dangerous Dave
Its the same with all GSXR and TL spindles as well guys!!!
Old 22-03-08, 10:25 AM   #108
Red Herring
Red Herring's Avatar
Things haven't worked quite as well as I thought with the speedo connection. With four magnets around the disc the speedo massively over reads (although having 120mph on the clock in third gear looks impressive). I reduced it to three, better, and then to two, but then it under reads (by about 10mph @50). It's also worth noting that with the magnets at uneven spacing it really confuses the speedo, especially at low speed where you get the figures jumping around by about 10-15mph. Haven't quite worked out where I have gone wrong, or an easy solution. Anybody else had this problem?
Old 22-03-08, 11:29 AM   #109
phil24_7
phil24_7's Avatar
Leave them out and have no speedo!!!
Phil
Old 22-03-08, 05:31 PM   #110
Rich
Rich's Avatar
When i've had my new wheel sprayed the correct colour how easy is it going to be to fit a new tyre for myself? Is there any sort of sealant needed on the RIM or does it just seal with pressure? I'd prefer to have a go myself, just wondering if it was an easy job or one best left to the professionals?
Oh and a pic ofcourse, i've only just checked my new discs fit and to my relief, they do ...
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
GSXR front end swap - front tyre profile. Khewett SV Talk, Tuning & Tweaking 12 11-05-06 11:24 AM
