#101 |
A friend who makes "provalves", a cartridge emulator which uses a shim stack instead of the coil spring on the RT emulators, had problems getting a soft enough setting on them. There is a LOT of oil being pushed through that valve on compression... Maybe running comp in one side only helps, since it immediately halves the comp damping
#102 |
You think too much highspeed could be cause of this chatter?
I would be looking into flex and what that does to the big piston.
#103 |
Steve said he couldn't get the air gap right and make the forks soft enough for the bike. Either way, I can't fault the forks - they're spot on.
#104 |
so did you get it dynoed?
#105 |
Will get it dynoed in the next 10 days.
In any case, raw horsepower doesn't really tell you very much about how the bike will work. Acceleration through time does. |
#106 | |
The air-gap should work just like in any other 43mm fork, I'd have thought?? Piston should be fairly tolerant of flex given the teflon sealing ring... tolerances are a bit looser than engine pistons ![]() I haven't had the guts of a BPF spread on a bench in front of me, so I'm guessing. I did hear that when the BPF's first showed up on the ZX6R, the serious folk all ended up binning the innards and fitting Ohlins or K-tech carts... Maybe Irie just needed some lead in his front axle to make up for that too-light front wheel ![]() |
#107 |
#108 |
#109 |
Well?
#110 |
84.5 rwbhp (dynapro) and 154 kg post race with 3 litres of fuel remaining.
Crash.NET - PICTURES: Early 2008 Suzuki breaks cover. | NewsBot | News | 0 | 25-09-07 10:10 AM |
