#111 | |
Silver SV650SK3, Fuel exhaust |
#112 |
#113 |
I can't imagine why a racer would deliberately downshift halfway round a corner, if it can be avoided. Might be necessary in some chicanes or double corners I spose.
#114 | |
Back to thread: Blipping isn't essential, or even particularly important. It's an improvement. Those who don't do it aren't going to suffer, but try it, you might find (as I did) that you like the effect. |
#115 |
People are generalising about braking in a corner too. I often drag my back brake a touch in a corner, either to scrub off a little speed, or sometimes if the corner was bumpy or uneven I'd give it a wee touch to bring the rear shock under control.
You can trail the front brake even after you've tipped in to a corner, so long as you are smooth in your transition from brakes back onto the power, and your prepared to push the bike back down if it starts to stand up a bit. Even if the SV standard suspendies can make that a bit interesting if if bumpy or uneven. Do it on something like a BMW with a funny front end and it doesn't feel dodgy at all. Braking and cornering together just needs some thought about your stability, and you need to be confident that your tyre and road conditions have enough grip to deal with the forces involved. This is not advice for anyone and "don't try this at home kids", but lets not generalise and say that it can't be done or will result in certain death. Last edited by -Ralph-; 26-05-10 at 12:01 PM. |
#116 | |
You can carry quite alot of speed into a corner and gently scrub speed with the front brake but you really need to balance braking and cornering as you cant do both heavily. If I remember the Keith Code approach to this is to consider having 1$ worth of grip, you can assign some to cornering and some to braking but the limit is finite. |
#117 |
F = uR
#118 |
#119 | |
DaffyGingerBint
As for braking in a corner.....I would say on a track braking and gera changes in beg corners would sometimes be necessary....but on a road, I would still advocate doing to the vehicle what is least likely to cause it to lose traction or control...so just prepare for the corner before you get there. I was only talking about road riding/driving, not racetrack. As for blipping.....I'll wait til I've been riding a fair bit longer and see....I think I already do it. |
#120 | |
Braking and downshifting required... horrible corner.
6.67300 × 10-11 m3 kg-1 s-2 |
Blipping the throttle | Holdup | Bikes - Talk & Issues | 50 | 16-12-09 10:06 AM |
Blipping the throttle | ArtyLady | Bikes - Talk & Issues | 30 | 30-06-09 05:56 AM |
Blipping the throttle after changing down a gear. | Ruthja2801 | Bikes - Talk & Issues | 88 | 25-02-09 02:30 PM |
Blipping the throttle. | petevtwin650 | Bikes - Talk & Issues | 151 | 02-06-08 06:46 AM |
Is there a big disadvantage to not blipping the throttle on fast downchanges? | monkey | Bikes - Talk & Issues | 25 | 06-04-08 02:43 AM |
