Old 31-05-18, 06:04 PM   #1241
Toooldtodie
Toooldtodie's Avatar
Default Re: What have you tinkered with today?
Point taken. Cheers Bibio. Will take apart next weekend and re-apply RRG.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 31-05-18, 08:46 PM   #1242
R1ffR4ff
R1ffR4ff's Avatar
Originally Posted by Toooldtodie View Post
Cleaned my calipers for the N th effing time after riding through the winter and changed the brake fluid and bleed nipples for some s/s ones. Everything went to plan!! No sheared off bolts or endless bleeding... has my luck changed? or am I about to grab a handful of nothing and plough through a hedge? Or do I just need to cheer the hell up and accept some good fortune.
Once or twice a month on a clear straight road with no traffic in either direction and in front or behind me I check/test my brakes by doing an,"Emergency-Stop".
I'd rather find out when there's nothing about if there's any weakness in my braking system.
Old 31-05-18, 10:02 PM   #1243
littleoldman2
littleoldman2's Avatar
Fitted the chain and sprockets to the Van Van. Checked and greased the back brake at the same time. Then took it for a blast a few times round the storage yard where it's stored. Just got to bend the rear rack back into shape, fit a new front mudguard, repair the speedo outer casing and give it a final proper checkover.
Old 31-05-18, 10:28 PM   #1244
Red ones
Red ones's Avatar
If the sliding pin is stiff it first manifests as a gentle pulsing on light braking.
Old 01-06-18, 07:59 AM   #1245
R1ffR4ff
R1ffR4ff's Avatar
Yeh.I was getting that and the low-speed grabbing.It's was really noticeable when pushing the bike out of the garage
Old 01-06-18, 09:35 AM   #1246
proze
the muppets that you see on youtube cleaning callipers by spraying brake cleaner on the seals and pistons are just that.. muppets who dont know what they are doing.
That's okay if you're stripping and cleaning, no? As long as you're reapplying brake fluid and RRG on reassembly?
proze is offline   Reply With Quote
Old 01-06-18, 09:37 AM   #1247
punyXpress
punyXpress's Avatar
Not lost 'the need for speed' then, Malc
Hope all progressing well.
Now: Street Triple R
Old 01-06-18, 12:56 PM   #1248
i'm talking about the youtube vids where people think that taking the callipers off, pumping out the pistons then spraying with cleaner is cleaning them and its good for them... its not its worse.
to fully service callipers you need to remove the pistons, remove the seals, clean the seal recesses out then assemble everything with RRG. do not under any circumstances use brake fluid to install seals. most and even the suzuki service manuals tell you to use brake fluid but they are wrong. brake fluid is hygroscopic by nature so using brake fluid to install seals will actually pull more moisture back into your nice clean seal recesses which is the biggest cause of them "furring up" in the first place as the moisture reacts with the bare aluminium.
pretty much every seal kit comes with a small packet of RRG/silicone grease these days as its now common knowledge that you dont use brake fluid.
a 500g tub of RRG will last a lifetime and then your kids lifetime as well as you only need a "smear" of the stuff on the seals.
top tips:
use a dremel with a disc brush (and autosol) to clean out the recesses.
if you have seized or really dirty callipers then boil them in a pot with some "oxy" washing powder.
dont forget that if your callipers are needing done then bets are the master cylinders are needing done as well.
Old 01-06-18, 01:56 PM   #1249
R1ffR4ff
R1ffR4ff's Avatar
Totally agree with the use of RRG where applicable and all your other points Biblio.
I got a small tin ages ago off eBay as I didn't want a big tin around.
https://tinyurl.com/yc2t8bhk
Still got loads left
Old 01-06-18, 10:00 PM   #1250
dirtydog
Knob faced knobster
dirtydog's Avatar
I bought a 500g tub of rrg about 15 years ago and it's still almost full, that's after I've given away a few small pots of it to people
Today I have tinkered with taking out the exhaust baffle out, sounds much better now
2001 SV650 in shimmerin green, Not broken anymore
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
