Old 06-02-20, 09:29 PM   #1601
garynortheast
garynortheast's Avatar
Default Re: What have you tinkered with today?
Oil and filter change, and new reduced metal semi-sintered front brake pads. Pumped the pistons out a bit to give them a good clean, reapplied rrg to them and the sliding pins on the callipers. All back together now and working nicely.
Old 06-02-20, 09:31 PM   #1602
zsv650s
Good job my brakes are well over due splitting and doing properly I just can't bring myself round too it.
zsv650s is offline   Reply With Quote
Old 06-02-20, 09:47 PM   #1603
Adam Ef
Adam Ef's Avatar
I was putting off bleeding the rear brake on the VFR as heard bleeding linked brakes is a nightmare process. Turns out just doing the rear pistons that are actuated from the rear brake pedal on it's own is very simple. Fairly quick job and next time will be even quicker now I know to flip the caliper and remount it to hold it in the right position for bleeding.
Also ran some new fluid through the hydraulic clutch reservoir to flush out the dark brown sludge that was in there. Hoepfully it's all working for the commute tomorrow.
Past:
Old 07-02-20, 07:49 AM   #1604
admin
John T
admin's Avatar
I've bled the brakes on my VFR. It takes longer but it's not a problem if you follow a set process. There's a good link on the VFR discussions forum if you want me to dig it out.
Sent from my Nexus 7 using Tapatalk
Old 07-02-20, 10:58 AM   #1605
Luckypants
Luckypants's Avatar
After Grant's post in SOTD thread, I'm dreading him posting in here!
Old 07-02-20, 11:13 AM   #1606
punyXpress
punyXpress's Avatar
As long as he doesn't update his avatar !
Now: Street Triple R
Old 07-02-20, 08:41 PM   #1607
Red Herring
Red Herring's Avatar
Get yourself a large syringe with a short length of tube on it. Being able to inject fluid into the system via a bleed nipple makes the rest of the VFR linked system a whole lot easier to do.
Old 10-02-20, 04:26 PM   #1608
CheGuevara
Not quite today, but just recently changed out the original brake lines (to Hel) and fluid (to rbf600) in my low-mileage (<4K) SK9 SV. The fluid was getting pretty dark, brakes a bit spongy, but never the less I was surprised to find this build-up in the banjo bolts:
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 10-02-20, 04:36 PM   #1609
Chris_SVS
Chris_SVS's Avatar
Imgur is really good for this forum. Just select huge thumbnail and copy-paste link
Chris_SVS is offline   Reply With Quote
Old 10-02-20, 04:40 PM   #1610
CheGuevara
Cheers. Managed to get the google image to work, but I'm not wed to it, so will check that out.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
