Old 12-04-20, 06:41 PM   #1641
Adam Ef
Adam Ef's Avatar
Default Re: What have you tinkered with today?
Decided to touch up the flaking paint on the VFR forks today. Started by sanding off the worst of the flaking with the forks still on the bike. Realised that was going to be hard work so removed them...
That made it easier but then showed up how much hidden bad patches of years or crud build up and knackered paint there is, so set about with a dremel and sanding bits too...
All turning out to be a more involved and time consuming process than I thought and as I intended to do it some time in the future decided I may as well strip everything down to do a proper service as I have a selection of fork oil from working on my SV. Worth doing now that the forks are off the bike as I probably won't get motivated to do it later...
Before I know it I've decided to go the whole hog and have order new oil and dust seals, bushes and then (because I may as well really do it right if I'm doing it) new uprated linear springs too.
So a small paint retouch seems to have turned into a full overhaul! I suppose it's the right time to be doing it. Got a few days to wait for parts etc now I expect.
Past:
Old 12-04-20, 07:10 PM   #1642
garynortheast
garynortheast's Avatar
He he! Jobs like touching up the paint never stop there in my experience Adam. One thing always leads to another.
Old 13-04-20, 08:37 AM   #1643
Craig380
I love the way the bike seems to be screaming at you in the first pic ...
"WHERE'S MY FRONT WHEEL GONE, YOU B*****D?"
Old 13-04-20, 12:23 PM   #1644
just a heads up for people wanting to install a "live switched" USB charger to their bike without my gizmo.
find an ignition live e.g. side light bulb and take a + feed from the input side of the bulb holder wire and connect that to the + of the USB charger. then connect the other - wire from the USB charger to either the battery - or the frame.
the above will also work for energizing the coil in a relay should you need to use one.
Old 14-04-20, 08:26 AM   #1645
dirtydog
Knob faced knobster
dirtydog's Avatar
Originally Posted by garynortheast View Post
The end that plugs into the holder is too fat and spreads the holder just far enough that it won't go back into the hole in the panel.
Hmmm I was pretty sure I bought some 286 led bulbs and they fitted straight in but now thinking a bit more about it it may have been some 509t bulbs I bought as I vaguely remember seeing a couple of spares when I cleaned out the garage a few months ago
Like these https://www.ebay.co.uk/itm/10Pcs-B8-...KBN3eASUfjFLNQ
2001 SV650 in shimmerin green, Not broken anymore
Old 14-04-20, 08:48 AM   #1646
garynortheast
Thanks DD, just bought a pack of them.
Old 14-04-20, 09:20 AM   #1647
Dave20046
Dave20046's Avatar
Cheers Bibs, just weighing up whether I can be bothered to mount one up front or whether I'll mount one next to the battery and have the lead flying up the bike when in use.
Old 14-04-20, 02:02 PM   #1648
zsv650s
I have to do this to my soggy sv1000 suspension at some point good job I bet it will make a good bit of difference to the ride quality.
zsv650s is offline   Reply With Quote
Old 16-04-20, 04:02 PM   #1649
Adam Ef
Adam Ef's Avatar
Waiting for parts for the VFR forks, so got to servicing the GSXR 750. It seems to run nicely and isn't too untidy for a 39k mile bike. It needs a very good deep clean and all fluids replacing. Also the very old Metzeler tyres will be swapped out for some fresh ones with only 100 miles on them I've got left over in the garage from my Street Triple.
Warming up to drop the oil. So good to have got that sound back...
YouTube Video
Getting into it...
Past:
Old 16-04-20, 08:59 PM   #1650
aj76
Looks like a nice bike
Is that a 'new' to you GSXR 750 Adam?
Just waiting on dealers to open again so I can have the reg/rec and brake recalls done on mine then will hopefully get to keep it for more than 400 miles this time
Sent from my Pixel 3 using Tapatalk
aj76 is offline   Reply With Quote
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
