Old 04-08-16, 06:54 AM   #1671
yokohama
Originally Posted by johnnyrod View Post
What filters are there, Yokes?
Not sure .... one's yellow I think. I'll check when I get home and post a couple of pics.
Old 04-08-16, 02:42 PM   #1672
johnnyrod
johnnyrod's Avatar
DONE IT! Finally got the Konica back in one piece. There was a little lever attached to the co-cking shaft that need its spring re-hooking, and another little lever made out of quite thin metal that had become a bit bent out of plane. I need to collimate and to clean everything under the top cover, will also measure the speeds, but it's working! Only slight query is how to collimate it, and that the front lens element hasn't screwed back into the barrel quite as far as before, hopefully it'll all be fine or easy to fix.
Old 04-08-16, 05:33 PM   #1673
Kenzie
Kenzie's Avatar
Cool, that's good to hear. Does it collimate like any other camara? Loosen the focus ring, set focus and retighten?
Old 04-08-16, 05:41 PM   #1674
yokohama
Pic of the Cokin stuff is here.
https://goo.gl/photos/9ApQjXgnYob8BG2n8
There's a couple of holders, a round polarising filter and blue and yellow square ones.
Also a set of 'creative masks.'
I probably won't use any of them so up for grabs.
Old 04-08-16, 06:05 PM   #1675
johnnyrod
johnnyrod's Avatar
Kenzie - no, no idea yet. The focus is nearest the body. It's unit focus so this is where it all moves from.
Will pass I think Yoko, I wouldn't know what to do with those. Coloured filters are mainly for monochrome stuff but I usually shoot colour. Are they worth anything?
Old 04-08-16, 06:40 PM   #1676
yokohama
I can't see them being worth very much but I'm reluctant to just dump them. I'll hang on to them and see if I can pass them on sometime.
Old 04-08-16, 07:28 PM   #1677
johnnyrod
johnnyrod's Avatar
Looks like people do buy them, there are a couple of recent sales for £6 or so with multiple bids on ebay. I'd say with some good pics and a bit of googling so you can say something convincing in the advert they'd go for £5-10 plus postage, which you might be able to squeeze into large letter, in which case you can offer it "free" as it's only about £1.20
Old 04-08-16, 08:13 PM   #1678
Kenzie
Kenzie's Avatar
Made myself some redscale film using an old Kodak roll from a bootsale find and some Vista 200. Loaded it into my Cosmic. https://awareofthevoid.com/2014/06/1...ale-film-35mm/
Old 05-08-16, 08:11 AM   #1679
yokohama
Hope you'll post some of those when they come out. It'll be interesting to see the results.
Old 05-08-16, 05:24 PM   #1680
Kenzie
Kenzie's Avatar
Will do. Read that you need to overexpose to get better results. Normal exposure will produce a very red image. The QL19 arrived today, its a junker or otherwise in need of Johnny levels of surgery. I think one of the aperture blades are broken.
https://www.lomography.com/magazine/...position-tips?
