#1871 | |
Oil level is a good shout but if not right on the 'F' line shouldn't be the issue... you did check it upright (off the stand) and on flat ground didn't you? ![]()
#1872 | |
The Smith n Allen 10w40 semi synth is supposed to be a very good quality oil so I'm not duly worried about that, bike was checked on the flat and level and perfectly upright, oil level is bang on the top (full) mark. As yet I haven't ridden it but will do so soon, then I can see what difference the semi synth oil has made (if any), if there's no noticable improvement I'll experiment with dropping a little oil out so it's just below the top mark and see if the clutch stops dragging. The bike has only done 12000 miles, 1999. The clutch basket is perfect with zero signs of wear, the push rod is straight and true, the clutch worm has been thoroughly cleaned and regressed, cable is free and lubricated so ... I'm hoping it's an oil type/ level issue as I've read many times that the SV is sensitive to type and level. Here's hoping. |
#1873 | |
https://en.wikipedia.org/wiki/Molybdenum_disulfide https://www.engineersedge.com/lubric...cteristics.htm Some people like myself believe in it and some don't. I've been using it for over 40 years on older engines. Even oil companies have caught up as some Higher priced/spec engine Oils now contain it. Contrary to some people's beliefs it does not affect the fibrous Clutch plates and does not cause,"Clutch-Slip". https://blog.fcpeuro.com/heres-why-l...actually-works I also use a bit it to make my own Chain lube/oil.
#1874 | |
I didn't mean the cheap in a snarky way but I I used putoline which (used to be?) regarded as a cheap oil and it's £24 for 4l - I guessed at £19 smith & allen may have ommitted something. Quality wise , if it's all stamped up it will be quality enough (longevity good to a year at least too) - but the shared engine and clutch oil does need a bit of thinking about - you need the engine to be lube'd and the clutch to be able to grab to some extent.
#1875 |
I been tinkering.
Full service, new boots (my favourite brand) and a new clutch. ![]() ![]()
![]() Last edited by Dave20046; 22-09-20 at 06:37 PM. |
#1876 | |
#1877 | |
#1878 | |
I probably will drop a little bit out if the clutch still drags and fingers crossed ... it may return to as it was before the oil changes. |
#1879 | |
https://cx500.000webhostapp.com/SV650ClutchLifter.html
#1880 | |
