Old 26-08-14, 06:47 PM   #181
goodgumbo
Default Re: Bar conversion with pics
Very cool.
Old 26-08-14, 07:55 PM   #182
i clean my chain with scottoil with a cut down 2'' paint brush so its nice and stiff.
Old 28-08-14, 08:20 PM   #183
Jayneflakes
Jayneflakes's Avatar
The joy of worn out bearings is that they are really easy to replace...
sy69 by Jayne Carter, on Flickr
I have also just discovered that Suzuki call this a "Rear Cushion Lever", thanks to my brother in Law who works in the trade.
Is it really any wonder I have been complaining about an unresponsive rear end?
Some are easier to replace than others.
sy71 by Jayne Carter, on Flickr
I will have to admit defeat at this time, I cannot get the bearing out of the swing arm, I need the wife's help with this one. I struggled with the knuckle, but this is another story. The pain this caused my shoulder has put me back a few days, maybe I will get this out next week. At least putting them back in is an easier job.
Jayne you're a Pussy Magnet
Last edited by Jayneflakes; 04-08-16 at 01:33 PM. Reason: Facebook stole my photos and put them on the street for sexy cuddles!
Old 30-08-14, 02:21 PM   #184
Jayneflakes
New bearings...
Any one know what grade of bearing seating glue I should use on these or if I need any at all?
The next new part, a grease nipple. Why did Suzuki not fit them?
sy73 by Jayne Carter, on Flickr
This is a test fit, I have to source a thread sealant to make sure that it cannot come our or leak grease when I charge it.
sy74 by Jayne Carter, on Flickr
Last edited by Jayneflakes; 04-08-16 at 01:35 PM. Reason: Some one farted and blew my pictures away
Old 30-08-14, 03:28 PM   #185
Bobbydigital36
Grease nipple idea is really cool, saves a lot of hassle in the future.
Old 31-08-14, 08:31 PM   #186
Jayneflakes
I have been playing today.
sy79 by Jayne Carter, on Flickr
I also fitted the new bearings to the suspension rocker, I mean the Rear Cushion Lever!
sy78 by Jayne Carter, on Flickr
Last edited by Jayneflakes; 04-08-16 at 01:36 PM. Reason: Facebook sold my pictures to Pornhub!
Old 01-09-14, 08:53 AM   #187
Geodude
Geodude's Avatar
Love them bones Jayne, class
Old 01-09-14, 02:04 PM   #188
Jayneflakes
Thank you, I had to add a little colour to them.
Old 01-09-14, 04:43 PM   #189
Jayneflakes
What is going on with the bearings in the swing arm for the suspension rocker? I tried to get them out and had to admit defeat, which I put down to my poor health and being generally useless. So Carol had a go and managed to get one side out. It took some major hitting with a drift and finally slid out with a rusty slimy ooze of the freeing oil I had to use to get the bearings apart to start with.
The second bearing though has just shattered. The cage that holds the rollers has mangled up and the rollers have all fallen out. the shell of the bearing has broken leaving behind just the flat sides and we have no purchase for the drift. Carol has now admitted defeat and has gone to see a friend of ours who is a retired engineer to ask if she can machine the shell out using her workshop.
In all of my years of fitting and using sealed bearing races in both bicycles and now motorbikes I have never seen a bearing simply shatter like this. Even the bearings I have fitted to old titanium racing bike hubs were easier to do than these. What should have been a simple twenty minute job has turned into a painful angry nightmare for me...
Damn you Suzuki, we are not friends at the moment.
Old 01-09-14, 04:56 PM   #190
they are designed to be taken out with a blind bearing puller or pressed out using a press. if a shell gets stuck then get a joiners wood chisel and slice the shell or a hacksaw and cut a groove, once you have 'split' the shell then you can 'roll' it up inside and it will just drop out.
HID conversion stuballs SV Talk, Tuning & Tweaking 10 29-12-09 01:08 PM
m4a - mp3 conversion embee Idle Banter 17 04-06-07 09:22 AM
700 cc conversion CHICKENSTRIPS SV Talk, Tuning & Tweaking 23 30-08-06 02:56 PM
once again, the svs to sv conversion... littlewhitedaisy SV Talk, Tuning & Tweaking 33 24-05-06 03:51 PM
which air box conversion? Londonoz Exhausts 2 20-01-05 02:43 PM
