Old 30-10-12, 07:14 AM   #1941
The Idle Biker
Default Re: INTERESTING FACT OF THE DAY
In most cases a shark will only attack you when you are wet :-/
Old 31-10-12, 02:37 PM   #1942
The knights Templars invented the cheque.
Old 31-10-12, 08:33 PM   #1943
svrich
And international banking.
Old 01-11-12, 05:10 AM   #1944
L3nny
L3nny's Avatar
Also water is the leading cause drowning.
Old 01-11-12, 06:08 AM   #1945
Actually it's not, it's lack of oxygen.
Old 01-11-12, 06:24 AM   #1946
L3nny
L3nny's Avatar
There is plenty of oxygen in water
Old 01-11-12, 06:35 AM   #1947
Berlin
Which is why a fish doesn't drown when you take it out of water. It dies of too much oxygen. Water at 15 degrees C contains about 10ppm dissolved oxygen, or about 0.001% Air is about 18% oxygen.
A fish can live outside water for far longer than we can live under it because oxygen poisoning is a slow process and you suffer few side effects from short exposures (why fish can be returned to the water 10 minutes after being caught for some fish). As it recovers it's not waiting for the oxygen level in it's blood to to go up, it's waiting for it to go down!
C
Old 01-11-12, 07:28 AM   #1948
widepants
widepants's Avatar
Andrew smith talks twaddle
widepants is offline   Reply With Quote
Old 01-11-12, 09:02 AM   #1949
As a diver I can say confidently that for all practical terms for human survival there f***ing well isn't!
What may class as interesting is that in many cases of drowning when water hits the back of the throat it causes the larynx to go into spasm and close off the airway, meaning you drown without water getting into the lungs.
Old 01-11-12, 09:08 AM   #1950
Owenski
Is there not also supposed to be a moment of euthoria just before you die, at the point where you're airways open and you try to breathe... then fail horrifically.
This looks interesting! shifter SV Talk, Tuning & Tweaking 7 09-03-08 05:15 PM
Stalker Fact of the Day Kinvig Idle Banter 22 21-08-07 08:00 PM
Interesting Fact ArtyLady The Essex Lounge 19 28-02-07 05:34 PM
An Interesting day out 24/25 Feb? independentphoto SV Ecosse 3 18-02-07 07:02 PM
