05-11-09, 11:04 PM | #11 |
Re: cbr600f3 fork internals
He is right, 3 port high flow are good pistons, you just need to revalve it. It is old set up and pretty light on valving.
06-11-09, 12:06 AM | #12 | |
Anyhow, for anyone thinking of doing this mod, I would say go ahead and do it. In the end it won't cost much more than a Race tech fork, and you'll have some thing adjustable and unique. By all accounts, people that know, say the fork internals are a pretty good starting point as is. Much better than the stock SV, potentially better than an SV fork with Race Tech Emulators fork if setup right. With the clip ons above the triples you come pretty close to the N riding position I'll be using stock S model clipons with it instead of regular bars. The adjusters would conflict with the bars, since the forks are about 40mm longer when converted to CBR internals. |
28-09-10, 01:37 PM | #13 |
Sorry to bump this old thread, but does anyone know if you can fit the Honda F3 fork tubes and cartridges into 2nd Gen/Pointy fork lowers?
28-09-10, 02:10 PM | #14 |
If the forks are the same diameter (41MM) it should work. I have them in my Gen1. As long as the damper rod is held to the bottom of the fork with a bolt you should be able to get it to work.
It was not that complicated to make it a go, but it did take fiddling. |
28-09-10, 07:55 PM | #15 |
Re: CBR600F3 fork internals in SV forks?
Thanks, sounds like it should work; pointy forks are 41mm same as curvy, and damper rod is held in by a single bolt.
29-09-10, 04:38 AM | #16 |
29-09-10, 07:28 AM | #17 |
I was wondering if I could use the longer F3 fork tubes and put the clip ons above the top yoke for a bit of touring next year - is this possible?
29-09-10, 07:38 AM | #18 |
Not sure you will have enough length for clipons above.
22-11-10, 12:22 AM | #19 |
Why not just fit the entire F3 legs?
22-11-10, 08:33 AM | #20 |
Because then you'd need the Honda spindle which may not fit the SV wheel (anyone know?). Even if it did you'd have to sort out the speedo drive and caliper mounting issues as I doubt the CBR has exactly the same disc size and spacing as the SV. Or you could use the CBR front wheel and have non-matching front and rear wheels I suppose, but still leaves the speedo to fix and the CBR front mudguard to paint to match the rest of the bike. Just a lot of work. |
New fork internals on the market | zunkus | SV Talk, Tuning & Tweaking | 106 | 08-01-09 08:32 AM |
k5 fork internals | Snap | For Sale - SV's and SV related items | 0 | 28-10-07 06:24 PM |
Thundercat fork internals? | Lozzo | SV Talk, Tuning & Tweaking | 5 | 14-08-07 11:07 AM |
New front fork mod - cartridge-like internals | Knaapie | SV Talk, Tuning & Tweaking | 11 | 06-05-06 09:15 PM |
Upgrading the internals on stock SV forks? | Knaapie | SV Talk, Tuning & Tweaking | 36 | 19-02-06 11:30 PM |
