#11 | |||
![]() Anyway I suspect that, as is commonly the case with cars, the exhaust manifold you had fixed is iron, but the SV has no manifold and the motor is aluminium.
#12 |
thanks for the advice - will pul the exhaust off and clean it - drill some holes at the same time.
G |
Pattern exhaust joint gaskets? | tonny006 | SV Talk, Tuning & Tweaking | 6 | 21-01-09 10:24 AM |
can you crack this? | Dave The Rave | Idle Banter | 9 | 11-03-08 03:56 PM |
Anyone know how to fix a rose joint? | Bear | SV Talk, Tuning & Tweaking | 16 | 30-10-07 07:40 AM |
Joint bank accounts | rubberduckofdeath | Idle Banter | 13 | 18-01-07 04:28 PM |
