24-04-06, 11:40 AM | #11 | ||
will probably suceed-------in getting the bike to the bottom of the hill whilst all that bouncing about may shake up a bad connection, it's not an orthodox fixing method Quote:
Cheers Mark.
24-04-06, 11:44 AM | #12 |
Hi mate
Under the seat next to the fuses is a relay, which works the indicators. Haynes tells you how to check it. Might have been sh$%&d by your regulator problem. If you havn't got a haynes manual let me know and I e-mail you a scanned sheet from mine Tris |
24-04-06, 12:41 PM | #13 |
I won't risk the bump start. Don't think i have the energy to push back up. If it doesn't rain tonight i will swap the coils round. Look like i will have the whole bike in pieces b4 i find the problem.
Tris - i have sent u a PM. Thanks |
24-04-06, 07:13 PM | #14 |
Had a look at my lighting again and the bulbs were all blown. Not sure what i was testing before. i have now replaced 5 blown bulbs and its working ok. Tomorrow will be the battle of the ignition coil. Hopefully, its just the coil, if not, CDI next
24-04-06, 07:17 PM | #15 |
As you had a reg/rec problem it's possible an overvoltage has popped bulbs, hopefully it hasn't taken anything dearer with it.
27-04-06, 06:12 AM | #16 |
Doe Mate
I got my hands on the replacement CDI and she fired up first press of the button. It was the only thing on the bike I couldn't test! Hope you're making progress and yours is working soon Tris |
27-04-06, 12:03 PM | #17 |
Hi Tris,
Good to hear u got yours going again. I am picking up a new coil today as there is no spark from one. I am already trying to source for a CDI unit just in case. What's the best way of reaching the CDI unit? Hope to get mine working by saturday. Doe |
27-04-06, 12:17 PM | #18 | |
Friday evening I'm going upto Royston, if you need it and if I've got another, and if you're not to far away, the possibility exsists I maybe able to drop it off ? PM me you number and I'll give you a call probably 5 ish Friday if you're interested and can't get one from another source. Cheers Mark.
27-04-06, 12:33 PM | #19 | ||
No you didn't. Quote:
Click me for an explanation.
27-04-06, 12:54 PM | #20 | |||
Cheers Mark.
My Bike Won't Start :( | arcdef | SV Talk, Tuning & Tweaking | 34 | 01-02-09 08:38 PM |
Help! bike doesn't start | DJ828 | Bikes - Talk & Issues | 10 | 26-03-08 11:12 PM |
bike won't start | magicrat | SV Talk, Tuning & Tweaking | 9 | 16-02-08 02:31 PM |
My Bike Won't Start! | Yellow | Bikes - Talk & Issues | 4 | 01-09-07 08:31 PM |
Clocks start spinning and bike wont start?! | lockery | SV Talk, Tuning & Tweaking | 4 | 13-04-06 07:32 AM |
