09-11-05, 03:01 PM | #11 |
I get this on mine (naked Y-model curvy)
about once a month, always when I least need it (ie always engine breaking, generally approaching something at speed) I have found that you get a warning, one sputter on the downshift. I have a sneaking suspicion its something to do with fueling and the idle rate as it only occurs on a closed throttle after the bike has had some "abuse". I have found that getting the throttle open again, even a bit, prevents it from actually stalling. So its either airflow, fuelling, or not sparking ( I would expect unburnt fuel with that last one and there isnt any soo....) I was hoping a freer flowing airfilter and a new end can may improve things but havent the cash to do it. Aside from that, everything else is clean / doing what its supposed to do BTW happens a lot less using Texaco, Shell or Esso High RON fuel (if ever) but more regularly on BP High RON and normal RON crap |
10-11-05, 07:40 AM | #12 |
OK checked last night and the fuel lines seem to be fine (But will check again at the weekend when there is more light)
As for the water 0 I don't think that's it this time as it doesn't stand in rain any more. The shop tested the drain pipe and said it flows freely, they alos said they tested the filler cap and it also flowed freely, explaining the rust on the inside of the filler cap (I suppose I should have noticed this earlier ) Anyway, just some more info to see if it sheds any more light on the issue... Not done the whole stopping thing again, but... When riding at 100kmph for 30kms or so if I pull on the throttle it's very hesitant, then seems to sort itself out (in a sec or so) and pulls normally. Would this just be carb icing? I've had that in the past and it normally causes it to be a pig when slowing down for traffic lights and I've not had this yet this autumn. TIA again folks, Stu |
10-11-05, 08:23 AM | #13 |
Sounds like carb icing to me.
I used to get on the SV after doing a similar distance. |
10-11-05, 08:53 AM | #14 | ||
10-11-05, 09:23 AM | #15 |
Wasn't raining at the time was it?
10-11-05, 09:46 AM | #16 | |
Stu |
The Joys of Monday Morning... | gettin2dizzy | Idle Banter | 27 | 15-09-08 03:48 PM |
Friday afternoon rant | Ed | Idle Banter | 18 | 15-06-07 10:02 PM |
Something for a friday afternoon... | Baph | Idle Banter | 8 | 16-12-06 09:59 AM |
Friday Afternoon Joke | Jabba | Idle Banter | 11 | 15-09-06 02:10 PM |
Monday Morning Plonker | Daimo | Idle Banter | 14 | 10-04-06 11:43 AM |
