View Poll Results: How should Mr Endo lube his chain | |||
Clean with parrafin, dry with rag, lube with a good quality chain lube | 27 | 75.00% | |
Never clean it, lube with used engine oil | 9 | 25.00% | |
Voters: 36. You may not vote on this poll |
22-11-10, 02:27 PM | #11 |
Re: How should Mr Endo lube his chain?
LOL
22-11-10, 06:01 PM | #12 |
The Teacer
Or in my case - buy Scottoiler, sort out getting it fixed in, fixer changes mind, dry chain and scottoiler in cellar.
Doesn't matter anyway. Havent ridden it in ages. It'll be a pile of siezed rust before it gets looked at again |
22-11-10, 06:22 PM | #13 |
i find motorex 622 chainlube will last upto 1000 miles between applications and pos 200 to 500 miles in the wet and in winter when its salty,and i can get a chain to last upto 20000 miles or more on some bikes.and i have never cleaned a chain before
22-11-10, 06:45 PM | #14 |
S'cuse me mister....but I have cleaned all my chains with WD40 on a rag...then re-lubed with Castrol chain lube.
Where is theeese option huh?
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
22-11-10, 06:46 PM | #15 |
22-11-10, 06:47 PM | #16 |
Correct answer IMO is either.
If you are using old engine oil, probably 100 miles in between applications is OK. Good quality chain lube a bit longer but not much. Proper solution is scottoiler.
22-11-10, 06:48 PM | #17 |
But I can't, as its not specific enough
22-11-10, 07:05 PM | #18 |
22-11-10, 07:10 PM | #19 |
Its asleep, so now I get to talk dirty!
22-11-10, 09:01 PM | #20 |
doesnt engine oil damage the 'o' rings in the chain?
and using a scottoiler will only lube one side of the chain or put more lube on one side of the chain. i just buy can of chain lube and spray every few days or 200miles (i carry a can round with me most the time) clean with chain cleaner every services (3K intervals/monthly) |
S-DOC Chain Lube? | krhall | Bikes - Talk & Issues | 3 | 03-03-10 09:28 AM |
Used oil for chain lube | sunshine | SV Talk, Tuning & Tweaking | 26 | 27-09-09 09:39 PM |
How much lube? (Chain lube!) | AndyL | SV Talk, Tuning & Tweaking | 10 | 10-01-09 08:04 PM |
Chain Lube | jonhunt | Bikes - Talk & Issues | 7 | 15-04-07 09:38 PM |
Chain Lube | fred_dillon | SV Talk, Tuning & Tweaking | 12 | 25-05-05 08:30 PM |
