12-08-09, 03:17 PM | #11 |
Re: its that charging issue again :)
Just out of curiosity, how have you connected the heated grips?
If you haven't wired up a relay-controlled distribution block, then I highly recommend it. It ensures the grips are OFF unless the distribution block is powered, which only happens when the bike's lights (or however you've tapped into the bike's wiring harness) is on. (The taillight is easy, so things are ON when the lights are ON, and OFF otherwise.) And this setup keeps the accessories from draining the battery. |
18-08-09, 06:28 AM | #12 |
ok folks had another quick look last night but had to stop as the bloody washing mashine has started to leak!!!
Anyhow on idle i get 14v to 13.8v at the battery. however when its running at 5k with or without the lights it drops to 13.2v strange? |
18-08-09, 11:22 AM | #13 |
Reg rec isn't particularly happy then.
18-08-09, 11:37 AM | #14 |
its a diff one as well
18-08-09, 11:40 AM | #15 |
Have you checked alternator output? Possible something is breaking down under load though unlikely.
Should be 70VAC+ at a couple 1000 rpm. Want me to pop up and have a gander?
18-08-09, 11:55 AM | #16 |
aye it seems to be that voltage, ish.
welcome to pop up chap how are you fixed for wed? |
18-08-09, 11:56 AM | #17 |
I am working in Elland, can come straight up. Do you have a voltmeter?
18-08-09, 11:58 AM | #18 |
aye got one, got 2 infact. what are you up to in elland? and will you want tea or food?
18-08-09, 12:06 PM | #19 |
Brew please.
What time? I finish at 5 but can hang around.
18-08-09, 01:39 PM | #20 |
Ill be there about 530 if thats alright?
Charging Problems. | rugbyguy91 | SV Talk, Tuning & Tweaking | 1 | 16-07-09 06:58 AM |
Charging problem. | GeneticBubble | Bikes - Talk & Issues | 3 | 28-06-09 09:31 PM |
Charging - AGAIN | Tris | SV Talk, Tuning & Tweaking | 7 | 15-04-08 04:15 PM |
charging the battery | gico | SV Talk, Tuning & Tweaking | 3 | 02-04-08 05:39 PM |
Over charging | Tris | SV Talk, Tuning & Tweaking | 8 | 21-02-06 12:13 PM |
