Old 04-12-07, 12:51 PM   #11
POGS69
Default Re: Running rough, running out of ideas.
I had the same problem sort of
I had changed everything related to the fuel system and electrical system, ended up costing a load of money...It turned out, after much head scratching and pondering that when they fitted the alarm, they didn't cover the solder properly and the loom had begun to corrode.....I replaced the whole loom and have never looked back since
It might help just having a look at the wireing near the alarm wires...assuming the bike has an alarm
Hope this helps
Old 04-12-07, 01:50 PM   #12
Stig
Have you checked your main earth from the battery to the engine? If this is OK check further back. Considering all the checks you have made so far, I would check for a bad earth somewhere.
Old 04-12-07, 02:00 PM   #13
ELR4ever
Yeah, if you have an alarm, some wires might have been spliced into. For example, on mine, a laserline alarm required a cut into the power line going into my indicator relay to put a diode in. Otherwise, the alarm guy was telling me when the bike is turned off, with an indicator on, the ingnition stays on. Said it can also kill alarms. My indicators stopped working after going intermittant. Found out by uncovering the black tape on that wire and saw the diode. Diode was giving bad continuity, soldered in a new one and fine. Moral of story, yeah, you could have some chaffing or bad connection, but, sounds more to me like something telling the plugs when to fire or how hot is not working. Where's all the sparky geniuses on this site???
Old 04-12-07, 02:55 PM   #14
Originally Posted by gettin2dizzy View Post
Get a colourtune on it to see what's happening in the cylinder. Just don't electrocute yourself repeatedly with it.... which I'm sure no one has done....ever
Nahhh you'd have to be a bit thick to zap yourself with a colourtune...
Old 04-12-07, 04:19 PM   #15
gettin2dizzy
Especially as it would (I think) repeatedly zap you for ages and make it really difficult to stop. You'd be a right goon to do it twice
Old 04-12-07, 06:37 PM   #16
Sarj
Good hint, thanks, I'll definately check the earthing/loom tomorrow...
Oh and have a look at the ecu?
Oh, and I've had the same problem with the diode leg, much fun... NOT!
S
Old 04-12-07, 06:45 PM   #17
drefraser
But I'd laugh louder if I hadn't just sent my exhaust baffle into the dark recesses of the can while "easing" it into place. Or maybe everyone ends up installing them from the engine end of the exhaust?
Old 04-12-07, 06:45 PM   #18
Best way to check the ignition unit is to swap with someone rather than risk ebay
Black box trouble is fairly rare though
Rough running and noise. arcdef SV Talk, Tuning & Tweaking 31 25-03-09 08:57 PM
rough running ? mikey devon SV Talk, Tuning & Tweaking 11 21-03-09 12:07 AM
running rough this morning AndyBrad SV Talk, Tuning & Tweaking 5 10-09-08 11:51 AM
Running rough when hot svdemon SV Talk, Tuning & Tweaking 3 13-08-08 07:44 PM
Running Rough? mike_b SV Talk, Tuning & Tweaking 3 20-12-06 11:38 PM
