Old 13-03-09, 09:43 AM   #11
plowsie
Default Re: No Speedo, No Lights, No Rev Counter, No Dash...
Hmm, you sure you haven't got front lights? Rear light didn't work on mine when it went, but the front lights are on a seperate fuse...hmm, interesting. Think check your fuses then as Grinch says, check the 30.
Old 13-03-09, 09:55 AM   #12
JamesMio
Thanks - I'll double check it again and come back to you.
"That **** on the push-bike."
Creatomatic
Old 13-03-09, 11:07 AM   #13
Baph
Originally Posted by JamesMio View Post
Ok, thanks.
I've got no headlights / indicators either by the way - likely to be the same fault do you think?
Aha, see, curvy, and no indicators etc. That'll be fuse 4, signal. Fuses 1 & 2 are headlights (lo & hi). Fuse 3 is ignition & 5 is the instrument cluster.
The signal fuse is the 15A one, with 10A either side of it.
try the fuse marked lights (I think??)
Infact inspect all the fuses anyway but swap the signal and lights one (if it is called lights) see how you go, may well be knackered wiring up front end though (I hate electrics )
See above.
I was hoping someone knew of an eastern European midget I could rent for half an hour or so. The connectors behind the headstock are nigh on impossible to get at (after going to the trouble of removing airbox and throttle bodies even!!)
Old 13-03-09, 11:35 AM   #14
Your lucky you got summat...I got nadda.
Soembody was supposed to have solved my electrical problem. It always seems to reappear when I'm looking forward to a day of meee time. I am currently taking off all my fairings, and doing to fffing job myself.
Blown fuse....again. Somebody was supposed to have checked the wiring loom round the headstock etc. Guess what I've just found???
So just tape it up, and check the rest? Will that be enough?
Old 13-03-09, 11:48 AM   #15
Baph
If you have a wire that's rubbed on the frame or somewhere - so long as it's not gone through the metallic core of the wire, then yea, just insulation tape around that wire to isolate it, then more tape around the bundle of wires to protect it in future.
Old 13-03-09, 12:10 PM   #16
Dave20046
Dave20046's Avatar
i use ignition sealant too on everything
Old 13-03-09, 12:38 PM   #17
now then, just fettling round the loom over the left side of the nose cone. bunch of wires there, I've found a pink one that has worn through, a fine thread of copper is just severed from the core, can I just wrap tape round it, or do I have to do something to it first?.....bearing in mind that there are no so called experts at home, and theres just me for the next million hours!
Old 13-03-09, 12:57 PM   #18
Grant66
Grant66's Avatar
If your talking about a single thread then just wrap the individual wire to cover the gap in the insulation (making sure the fine thread isn't sticking out), then wrap the a bit more (tape, or use some spi-wrap) around the entire cable loom to stop future chaffing.
In case your wondering what spi-wrap is:
http://www.maplin.co.uk/Module.aspx?ModuleNo=26849
Grant66 is offline   Reply With Quote
Old 13-03-09, 12:59 PM   #19
Luckypants
Luckypants's Avatar
If the majority of the core is OK, wrap it in insulating tape and all should be well. Check all the other wires to. You might want to wrap the whole loom in an old inner tube or summat to protect against future chaffing.
Old 13-03-09, 01:10 PM   #20
I've taped over the very small worn part, then I've taped over the taped bit on either side to stop any moisture getting under that. I've retaped the main cover that the big bunch is coming out of. Pretty certain that theres no more, checked all the wires in that particular bunch, but now its raining
I can't see anything thats around any subframe, headstock or other metal thing damaged, apart from the clutch wires(that I originally found and taped up) and a main one from the right hand clip on or there abouts. Checked what i can see under the nose cone, can't figure out how to get that off ( and can't be bothered today) but the subframe is newly pwdercoated and not damaged so I doubt anything can be bare against paint to blow a fuse.
hmmm me and my mole like eyesight seems to have found more than those that know what they are doing....beginners luck eh (read as Dizzy is seething and fed up to the hind teeth of her beloved SV blowing up)
no lights on dash, nadda dizzyblonde SV Talk, Tuning & Tweaking 13 28-09-08 05:16 PM
Dash lights Question Rick-UK SV Talk, Tuning & Tweaking 3 07-12-06 08:59 AM
rec counter water light?/ dash lights BIKER-DENE SV Talk, Tuning & Tweaking 1 14-02-06 06:54 PM
Dash Lights sprocket SV Talk, Tuning & Tweaking 3 01-12-05 01:59 AM
SV 99-02 dash lights sprocket SV Talk, Tuning & Tweaking 5 31-08-05 12:38 PM
