Old 29-09-08, 10:06 AM   #11
Default Re: Help need a cam chain tensioner
Adjuster bolt? no there isn't one fella... tensioner is assembled from the other end. The M6 cap bolt is just there so you can put a lock piece in the back while you bolt it in.
Old 29-09-08, 10:53 AM   #12
philbond07
Ok that's right, but manual page 3-104 shows to install tensioner body first, then mount "spring holder" (or "cam chain tension adjuster") bolt.
If it works like this, one doesn't need the "locking tool".
Old 29-09-08, 10:58 AM   #13
What manual. What year bike.
The pointy ones are different, the curvy ones you definately need to hold the plunger back when fitting the tensioner otherwise you will break camchain.
Old 29-09-08, 11:24 AM   #14
philbond07
Aha ok I see sorry. My bike is a 2003 pointy.
page 3-104, chapter 3 (engine) official Suzuki manual: http://www.edubs.net/bikestuff/sv650...l/3_Engine.pdf
Old 29-09-08, 11:27 AM   #15
I've never actually done a pointy one, so it would be silly of me to comment.
Old 29-09-08, 11:32 AM   #16
philbond07
But I just checked the curvy manual too. They efectively mention the special tool procedure over there. The curvy's tensioner's installation is not described with use of a special tool: the tensioner is installed with 2 bolts, then the spring and central bolt are just screwed in. Remains to be ssen if there is still place to screw it in
I can barely reach it(front cyl.) with my hands.
Old 29-09-08, 11:38 AM   #17
I've got one in my hand now, just looking at the manual.
Old 29-09-08, 11:40 AM   #18
philbond07
Yeah you're supposed to remove the spring, unblock the ratchet-mechanism, push plunger back, reinstall, then spring& spring holder bolt.
If this is right, under the central bolt there isn't probably an "detension-screw" and "tool-blocking grooves" ?
Old 29-09-08, 11:40 AM   #19
The curvy one is totally different to that, the cap bolt is far smaller, the spring held inside the body, removing the cap bolt does not release the spring. Curvy one is held together with a circlip on the inside of it.
Old 29-09-08, 11:44 AM   #20
I know the manual refers to the bolt as an adjuster bolt but it's really not, actually have a look at one and see how it works you'll see what I mean.
Cam Chain Tensioner Jamie_SV SV Talk, Tuning & Tweaking 3 01-09-08 12:55 PM
cam chain tensioner gc350 For Sale - SV's and SV related items 4 30-08-07 08:47 PM
Cam Chain Tensioner Banus SV Talk, Tuning & Tweaking 1 22-07-06 05:05 PM
Cam chain tensioner Blue_SV650S SV Talk, Tuning & Tweaking 2 07-07-06 08:38 PM
Cam chain tensioner. Stig Stuff Wanted 8 11-12-05 06:14 PM
