18-05-13, 09:03 AM | #11 |
Re: Leaking Gas from Overflow Line.
It has been done, but it's not a realistic long term solution. The problem is that the filler is recessed into the tank, (which is why there's a drain*), as such you can't see if there's water in the recess before opening the tank, and if there is it drops into the tank when you open the cap.
*I know you know this.
Random Coolant overflow - Curvy. | victor_meldrew | SV Talk, Tuning & Tweaking | 11 | 01-04-12 08:14 PM |
clunks every now and then, petrol overflow leaking | piers | SV Talk, Tuning & Tweaking | 4 | 30-04-09 09:44 PM |
I need help with a bath overflow with built in plug wire | monkey | Idle Banter | 8 | 20-11-08 01:20 AM |
Stack Overflow In Line 0 - Anybody know what this is please? | SV-net | Idle Banter | 8 | 05-09-08 06:52 AM |
