27-05-16, 08:40 PM | #11 |
Re: Found a rubber washer
On a different note is the front sprocket nut suppose to have a small amount of movement in it.
Curvy With Lots Of Bits ...
But Still More To Come |
27-05-16, 08:45 PM | #12 |
Was the 10p by the front sprocket too?
27-05-16, 08:46 PM | #13 |
Lol unfortunately not Sent from my iPhone using Tapatalk
27-05-16, 09:02 PM | #14 |
29-05-16, 07:50 AM | #15 |
To give you a ensible answer, no it shouldn't have any free play
29-05-16, 09:31 AM | #16 |
.... and the rubber washer looks like the sort of thing you often get on screws holding screens on .................. but it might be something completely different.
02-06-16, 09:24 PM | #17 | |
Ummmm I can move it a couple of mm each way but that's it Sent from my iPhone using Tapatalk
03-06-16, 01:48 PM | #18 |
towards and away from the bike or side to side like it's not been tightened properly?
03-06-16, 03:25 PM | #19 |
hold the horses. if the front sprocket is moving front too back a few mm along with the nut then its normal play in the output shaft.
however if there is no locking tab/washer on the nut and its just the nut that is moving then yes its loose, if there is a locking tab/washer then i very much doubt that the nut will have come loose. if you put the bike on a paddock stand and put it in gear then move the back wheel you will feel play, this is perfectly normal. |
33bhp washer kit. | MrKarl | Stuff Wanted | 9 | 06-05-13 11:08 AM |
Curvy S rubber headlight rubber dust seal | otaylor38 | Stuff Wanted | 1 | 12-03-13 10:32 PM |
Grab Rail Rubber Washer for Pointy | copper kettle | Stuff Wanted | 3 | 23-02-09 07:49 PM |
Sump washer | The Mass | SV Talk, Tuning & Tweaking | 14 | 27-06-06 09:53 AM |
Mirror rubber washer for Curvy SVS | SpankyHam | Stuff Wanted | 0 | 30-04-06 07:18 PM |
