#11 | |
Do note that by changing the rear you'll probably need a longer chain (110 links as opposed to the standard S's 10 ![]() . |
#12 |
Yea, I was aware of the increased wear factor, but to be honest its not a major concern. Lets face it, with regular (daily) lubing, the SV doesn't exactly eat chains.
Could be tempted by the 14/46 option, although I think I shall bide my time, and listen to some more advice before I decide on what to do. So come on down folks, what has everyone got. Dan |
#13 |
Okay. Thanks for the great response. So, if I was to buy a Renthal 46 do I buy a standard front and replace the chain all at the same time. Do need to buy a different chain now that I am changing the rear sprocket ? Is this a job I can do myself - I am a novice DIY bodger !
#14 |
Yes get the standard front (15) and get a 46 rear and replace the chain (110 links for this mod is sensible).
#15 |
Hi guys, so if you replace the rear on an "S" K3 model to a 46 Renthal, then you have to replace the chain? to a 110 link? You deff cant use the stock chain I take it?
#16 |
It's not that you can't use it it's just that it will be stretched to almost maxumum leaving little or no room for adjustment - and if your chain's worn anyway then one, you probably can't adjust it correctly and two, you might as well get a new chain.
I learnt the hard way: always change your chain and sprockets together. . |
Chains Sprockets and wheelbases | yorkie_chris | SV Talk, Tuning & Tweaking | 11 | 04-04-08 05:27 PM |
Now I understand | Ed | Idle Banter | 6 | 01-03-07 06:35 PM |
Sprockets and Chains | LandanSam | SV Talk, Tuning & Tweaking | 4 | 15-01-07 11:38 AM |
Chains & Sprockets - Have searched already | andyb | SV Talk, Tuning & Tweaking | 10 | 04-10-06 05:15 PM |
Chains and Sprockets | tricky | SV Talk, Tuning & Tweaking | 10 | 14-06-06 10:00 AM |
