28-05-11, 10:03 AM | #11 |
Re: Hi all
Welcome.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground" The Stoppy King
28-05-11, 11:21 AM | #12 |
Re: Hi all
Afternoodle!
Thanks for reminding me, a trip to North Harbour req'd for yearly service! |
28-05-11, 12:55 PM | #13 |
Re: Hi all
Welcome to the mad house... Most of us are toilet trained (but I can't speak for the Spearies!)
29-05-11, 09:50 AM | #14 |
Re: Hi all
Hi and welcome!
29-05-11, 04:54 PM | #15 |
Re: Hi all
Welcome!
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
30-05-11, 08:23 AM | #16 |
Re: Hi all
Yup mad house being the main ting to worry about. If you ain't mad you soon will be!!
Failte!! |
