#11 |
Once you have the seat off, you will reveal the fuse/relay tray. Below that tray is the battery. That is what we are aiming for
![]() The battery will have 2 terminals. One Positive (+ve (red rubber cover and a PLUS sign stamped on the batery)) and one Negative (-ve). First thing to do is set the multimeter on DC volts ... if you get that exact one from maplins, then it is 3 clicks left/anticlockwise form the off position. The two terminals/probes you get with the meter need to go in the bottom two slots on the multimeter (bottom right). Red for red, black for black. The top red slot is for measuring current. We will use that later, but for now we want to measure voltage. Ok, so now the meter is set up, put one of the probes on the +ve of the battery and one on the -ve. You should get a reading on the meter at this point. Hopefully it will be >= 12v (its a 12v battery). |
#12 | |
![]() I'd say a better check for the 'drain' is to take the -ve terminal off and use the ammeter function of the multimeter (tell you how to do that later Nadine ![]() |
#13 | |
#14 | |
We can also check the A/C voltages at the alternator, even with a basic/cheap multimeter ![]() |
#15 | |
Hello Jambo and Blue SV, Ha! you really gave me some confidence now! That was nice and easy, I got everything you said, so I will do this all by tomorrow eve and then let you know what happened! Maybe I can sort it out myself in the end. Well, I don't wanna get to big-headed yet... Thank you very very much, all the best, Nadine |
#16 | |
![]() ![]() When you use the meter, make sure you have it on the correct setting for the appropriate job, else you will get some funny readings! ... once you take a measurement, type here what the setting was, what you tried to measure and what the results/reading were!! ![]() The most basic of tests (and the initial one) is the voltage across the battery. Firstly with the bike turned off, then the bike started! A charging system should obviously charge when bike is running, so ... if you get 12v->13v bike turned off (<12v and the battery is flat/faulty) and 13->14v with the bike running (remember to rev it up and down a bit and note voltage changes) then the charging system is fine and you have a drain/draw somewhere!! Is the bike alarmed by the way??? Its not uncommon for them to go a bit AWOL and start taking too much juice ... |
#17 |
#18 |
#19 | |
No, there is no alarm on it! |
#20 |
Any news?!!?
Need help with my SV in Bristol | NadineDieBiene | South & West Surfers | 4 | 25-01-08 01:54 PM |
Any near Bristol?? | _Stretchie_ | The Good The Bad and The Ugly Pub and Cafe guide | 2 | 28-02-06 01:26 PM |
Bristol | Lazzer | South & West Surfers | 8 | 31-01-05 09:31 AM |
