Old 23-01-08, 08:22 PM   #11
metalmonkey
Default Re: Fitting hot grips - bike won't start!
Originally Posted by aliman2000 View Post
Tried messing about with everything but nothing seemed to be loose. I then got it off the side stand, kicked it out of neutral then back in and it started fine. Reckon the neutral or sidestand switch are a wee bit dodgy but that'll be a job for a nicer day. It's been blowing a gale and pouring it down the whole time I've been out there.
With regards to fitting a relay I decided not to bother as I got the new model of oxford grips that switch off when the battery gets below ~12.7V.
The hot grips now work. Tested them and they started heating up, hopefully they'll get a tad hotter when I'm out and about. I need to find somewhere that sells heat shrink sleeving for the connections now as I don't fancy leaving the connections open to the elements. Any recommendations?
Cheers for all the input folks!
No it doesn't work I know this having left my grips on once my battery was totally flat, had be pushed to bump start my bike, remeber to turn them off otherwise u will have falt battery and won't be going any where
Old 23-01-08, 11:40 PM   #12
Lozzo
Originally Posted by Ter View Post
When you come to wire them in properly make sure you use a relay, one that will only power them up with the bike is on/running.
It's easier to find a switched live from the ignition switch that can handle a 5 amp feed to the grips. Daytona grips tell you exactly what colour cable to splice their loom into for different makes of bikes. On a Suzuki it's an orange wire.
Old 24-01-08, 03:31 PM   #13
Ter
To really benefit from the heated grips you should use muffs as well, stops the wind stealing 'all' the heat produced by the grips...
Old 24-01-08, 08:32 PM   #14
Stu
Trinity
Stu's Avatar
Do you work for M&P
That's their free offer this weekend free muffs with H. grips
Old 19-02-12, 06:20 PM   #15
Sizzle Media
Ive just fitted some Oxford hot grips that came free with a subscription to Ride magazine. I managed to do the job as instructed and opted for the simpler 'connect to the battery' option until I habve more time to do a proper fitting.
However, I have been turning off and starting my bike all day, a day which started with topping up the charge on my battery. About an hour after I had glued the grips in to place and stoppped for some lunch, I came back to a bike that refused to start. there is power as all the lights work but nothing when I push the starter. I decided to go back over the wiring and took the seat off to have a look, everything was secure, turned the key and hey presto, we're running. I then got down and dirty and started a full scrub down, checking if the bike started after each rinse - no problems.
I go to put the bike away and stall it driving through the gate, and the problem is back, dead bike. Its gone dark now so can't go through the seat removal process again to see if the problem resides there. Does anyone have any idea what the problem might be. i am totally new to this and literally have no logical idea what it might be because the battery has a charge and nothing I have done affects the ignition, the fuses are all fine and ive tried the kickstand, false neutral but still no luck..
fitting grips AndyBrad SV Talk, Tuning & Tweaking 25 15-02-09 08:12 PM
Fitting new grips RPC_SV Bikes - Talk & Issues 4 27-07-08 08:05 PM
Fitting Hot Grips! Jackie_Black SV Talk, Tuning & Tweaking 14 18-02-08 02:12 PM
fitting hot grips hovis SV Talk, Tuning & Tweaking 59 16-01-07 01:40 PM
Fitting Heated Grips Grinch SV Talk, Tuning & Tweaking 12 14-03-06 09:30 AM
