Old 23-01-08, 11:26 PM   #11
sv650k4
Default Re: Anyone with an 03 sv650?
is that 1 of them we gear indicator things that u mont up at the dash and it tells u wot gear ur in???its not part of the standard loom or anything that blue bit sure its not?
Old 23-01-08, 11:31 PM   #12
flymo
flymo's Avatar
no, its basically stuck in place of the gear position switch to fake the gear position to the ECU. Normally the ECU retards the ignition in 2nd and 3rd gears for noise/emissions regs, this basically prevents that ignition retardation.
Its just a plug in unit that you add to the loom. You can also make your own using instructions in the FAQ section of this forum. Its only there because it was fitted when I bought the bike so I cant vouch for its worth.
I will be putting the bike on a dyno test session pretty soon though when the race prepping is finished. One of the tests we'll be doing is to measure the difference with or without this unit.
Mike
Trading sv650 for sv650 sport?? Wycombe Dave Bikes - Talk & Issues 12 24-08-08 10:26 PM
Difference b/t US SV650 & UK SV650 rc-svs Bikes - Talk & Issues 3 01-07-08 08:05 PM
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator ThEGr33k SV Talk, Tuning & Tweaking 0 25-11-07 12:22 AM
will a 2002 sv650 s cylinder head fit my 99 sv650? bugsy46 Bikes - Talk & Issues 2 07-04-07 04:26 PM
Will the forks off of a 03-05 SV650 fit a 99-02 SV650? Clarker SV Talk, Tuning & Tweaking 3 24-05-05 09:30 PM
