Old 04-02-08, 10:00 PM   #11
Default Re: HELP - Oil in unwanted places
Originally Posted by Jonnierw View Post
The restrictiong was done by putting restriction rings in the fuel/air line and a throttle twist-stop on the throttle.
FI international kit then.
Unlikely to make it lean, it usually makes them rich.
Old 08-02-08, 05:58 PM   #12
Jonnierw
The problem with the bike wasnt as previously thought. The front cyclinder was gathering water from riding in the rain and shorting out the spark plug. After removing cleaning and drying the spark plug, it ran as it should.
Thanks for all the help guys.
Old 08-02-08, 06:38 PM   #13
shifter
I'm going on Land Rover experiance here, but on early deisal Landys the Crank Case breathers run into the air filter housing to reduce emissions. These can become blocked and cause crank case pressure to force the sump oil up the breather and into the air intake. Could this be a similar problem?
On deisal engines they start runnig on their own oil usualy till they go bang!
Extra unwanted bit in Firefox browser the white rabbit Idle Banter 5 15-11-07 02:48 PM
Unwanted MCC Bikeshow 1st - 2nd June. Moo The Madlanders 0 22-05-07 10:30 AM
Unwanted MCC Bikeshow 1st - 2nd June. Moo Rideouts & Meetings 0 22-05-07 10:30 AM
UNWANTED MCC`s 2nd **** OUT RALLY Moo The Madlanders 2 14-06-06 10:35 PM
