Old 06-03-08, 06:11 PM   #11
SAMMY650
Default Re: Handlebar conversion
Mirrors are mounted to lever brackets
Old 06-03-08, 06:13 PM   #12
sv650k4
then you will probley be ok 2 still use them with no problems etc...
Old 06-03-08, 06:14 PM   #13
SAMMY650
Thanks for all the info. Much appreciated.x
Old 06-03-08, 06:16 PM   #14
sv650k4
no problem! i could have sold you the yoke and clip ons if you had have said last week the the clip ons just went on sunday and the top yoke last night the only other clip ons i have are race 41mm ones they sit a bit lower than the standard sv/suzuki clip ons.
Old 06-03-08, 06:16 PM   #15
sv650k4
if you want them feel free 2 give me a shout!
Old 06-03-08, 06:18 PM   #16
Dangerous Dave
Yeap, no probs.
Old 07-03-08, 02:03 AM   #17
21QUEST
21QUEST's Avatar
Two ways of goign about it...depends on how much you want to spend/how good you want it look(arguably)
Option One--Using the 'Naked' Top yoke.
*you need a clipons similar to the Helibar(might even find some off another make of bike that might work) as the work with the naked top yoke. *Headlight bracket will need changing to an after market one or you can 'cut and shut' you original one
*Clutch cable
*I changed the throttle cable as can be a bit of an **** to route so it works properly....I'm a bodge meister but little things like that can get on me t*ts . That said IMMSMR , the naked cable just didn't want to sit right.
* Should be able to get away without changing choke cable as it doesn't do much
Option two---using 'Faired' Top Yoke
*OE bars not a problem
*Headlight bracket still needs changing. Same as above----after market(which most look a bit cack lol) or a 'cut and shut' as above.
*'Faired' Clutch cable
*Throttle cables
*use your 'naked' cltch cable as above
** Main issue with using the faired Top yoke is mounting clocks but I think a couple of people have done it on thesite so should be able to help with that.
Think, that's about it. All IMO
Ben
Nemo me impune lacessit.
Old 07-03-08, 02:17 PM   #18
SAMMY650
That was the next question, How do I remount the clocks, headlight and indicators? Any instructions by someone thats done it?
Old 07-03-08, 09:44 PM   #19
admin
John T
admin's Avatar
Try a PM to Zunkus. He's fairly regular in the site. I'm pretty sure he converted a naked SV into a Cafe racer, so he would have been down this route.
Old 08-03-08, 11:23 AM   #20
flymo
flymo's Avatar
I just found the hard way that the top S model yoke is not interchangeable with the naked bottom yoke. Looks like the forks on the S are slightly further forward than on the naked.
ABM comfort Handlebar Conversion Kit for Pointy SV650S nomad For Sale - SV's and SV related items 3 07-02-09 01:26 PM
Bandit handlebar conversion Warthog SV Talk, Tuning & Tweaking 0 05-06-07 09:13 AM
handlebar risers richspace Stuff Wanted 2 10-02-07 03:02 PM
FS: Good as new Handlebar conversion kit for pointy **SOLD** Knaapie For Sale - SV's and SV related items 7 04-06-06 10:02 PM
HANDLEBAR CONVERSION ON A FAIRED SV..!.. alexb SV Talk, Tuning & Tweaking 17 13-12-04 04:30 AM
