#11 |
its do-able alright but not with a kit u can buy from you local bike store, those kits are "get u home kits" a bike shop should be able to mend this properly from the inside.
#12 |
I cant tell where you're looking there!
Basically if its in the middle of the tyre then you can plug it. However, be careful, a proper plug is a vulcanised rubber mushroom and is applied from the INSIDE. I wouldn't trust the ones applied fromt he outside to do anything except get me home
#13 |
ok, thx for the info guys
#14 |
So you only need to get by for a couple of weeks right? if it were me in your situation, then I'd just keep riding it and pump the tyre up every couple of days (assuming it isn't losing silly amounts). But that is me
![]() If you can find somewhere to fit an internal 'mushroom' type repair, they are perfectly safe and looking at that pic, that tyre can be repaired ![]() |
#15 | |
Edit: The reason most places won't repair a tyre is that the manufacturers won't recomend it. This means in case the tyre fails the responsibility moves from the tyre manufacturer to the dealer that repaired it. In today's blame and claim culture many places just won't take that risk, even though if done properly the chances of failiure are very very small. I have used the type of repair applied from the inside of the tyre on a track day more than once...
Modern motorcycles are bloody brilliant, enjoy it while we can ![]() Last edited by jambo; 26-03-08 at 10:23 AM. |
#16 |
Easily repairable and safe too. I had a full length 6mm masonry drill bit through the Metz on my GSXR, roughly same place on the tyre. RAC (recovery) fitted temp plug - Local tyre place fixed it from the inside with a plug - no problem. Cost just ?25 (don't know what 'states would charge) which included fitting the wheel.
Screw in tyre | Bluefish | Bikes - Talk & Issues | 11 | 06-04-09 09:34 PM |
screw in back tyre argghhhh | Marksv | Bikes - Talk & Issues | 5 | 15-06-08 11:34 PM |
Got a screw in my tyre! | bad-sv650 | Bikes - Talk & Issues | 10 | 04-02-08 06:16 PM |
How many people on the AR got a nail/screw in their tyre? | _Stretchie_ | Idle Banter | 5 | 02-07-07 02:02 PM |
Big **** off screw in rear tyre | goof | SV Ecosse | 13 | 27-04-06 10:08 PM |
