11-04-08, 09:47 AM | #11 | |
Re: Doesn't want to start!
engulf - verb (used with object) 1.to swallow up in or as in a gulf; submerge: The overflowing river has engulfed many small towns along its banks. 2.to plunge or immerse, as into a gulf: He engulfed himself in his studies. |
11-04-08, 09:48 AM | #12 |
what the.....
11-04-08, 10:33 AM | #13 |
Flooded?
'52 Curvy S | So good.....it made me want to trump! If at first you don't succeed - use more gaffa tape. |
11-04-08, 10:54 AM | #14 |
OK so it turns the engine over but it won't start? It's important to list all the things it will do as well as the things it wont
If the engine turns over, you have petrol in the system, next questions are: Do you have a spark, any alarm / immobiliser, and exactly what year is it? Jambo
Modern motorcycles are bloody brilliant, enjoy it while we can |
11-04-08, 03:44 PM | #15 |
mmmh... ok, maybe "engulfed" was a too literal translation from Italian!!!
the battery works, but when I try to turn the motorbike on, the motorbike coughs and I can't switch on the engine.... is it possible that it is caused by too much fuel in the combustion engine and this cause a misfunction? How could I solve it? P.S. no alarms/immobiliser, it is the 2000 model. |
11-04-08, 10:36 PM | #16 |
right so you turn the key in the ignition and go to start the bike as normal.
it turns over as normal (press starter and listen to hear if it is struggling) but it splutters and coughs asif it is trying to start on one cylinder. have you tryed bump starting it? my mates old NTV would not start unless bumped. this is done by sitting on the bike, put up the sidestand and pushing the bike with you sitting on it. Then you stand up on the pegs, put it into 1st gear with the clutch lever pulled in. You drop yourself onto the seat whilst letting go of the clutch and pressing the starter button. the bike should fire. If you cannot get fast enough use a friend to push you and/or maybe use 2nd gear. cheers dan |
A sad start to the day | ooger | Idle Banter | 17 | 03-06-08 11:27 AM |
Wont start, but will bump start :( | Wally | SV Talk, Tuning & Tweaking | 6 | 10-08-07 02:02 PM |
She won't start! Help! | Bear | SV Talk, Tuning & Tweaking | 43 | 19-12-06 11:39 AM |
yet another won't start, 01 650 | mann650 | SV Talk, Tuning & Tweaking | 4 | 25-07-06 03:54 PM |
Clocks start spinning and bike wont start?! | lockery | SV Talk, Tuning & Tweaking | 4 | 13-04-06 07:32 AM |
