Old 28-04-08, 09:14 AM   #11
flymo
flymo's Avatar
Default Re: Front end wobble?
Nothing at all wrong with the SV handling. Its as stable as its going to get to be honest, no problems whatsoever even when pushing it very hard.
+1 on the steering damper, no need at all. Even if you did fit one it shouldnt be to sort out a wobble thats there most of the time.
Start with pressures as has been mentioned, also dont assume that the wheel has been balanced properly. I've had loads that weren't. I fit my own tyres for the race bike so that I know for definate. In the garage you might well get a "yeah, thats close enough" as they obviously cant spend all day on your wheel alone. For me though, I want it spot on and I'm prepared to take the time to get that.
Start with the easy things to check and if it still remains post back here.
Old 28-04-08, 11:56 AM   #12
BillyC
BillyC's Avatar
Strange... mine's steady as a rock. Check everything that's already been said - but it could also be down to uneven wear on the tyres.
Old 29-04-08, 05:52 PM   #13
Ian1971
So what should the tyre preasure be? im running continental road attacks and have just checked 27.5 on the front and 32 on the rear, according to hanyes its 30 something but what ive read on here suggests 42
Old 29-04-08, 07:18 PM   #14
FATTYMATTYUK
I have the same problem i have checked everything tyres, wheel bearings, even the balance of the wheel but but still can't find the problem.
Old 29-04-08, 07:29 PM   #15
Frank
my bike used to wobble all the time at most speeds.
Two new tyres later with wheel balancing and all wobbles have gone.
Could have been square rear tyre,missing weights,will never know,but its a different bike now
Old 30-04-08, 10:39 AM   #16
Dangerous Dave
I know it is 36psi front and rear with Bridgestones, just checked a pair!
Old 30-04-08, 11:03 AM   #17
BillyC
BillyC's Avatar
Unusual... they used to recommend the 33 front, 36 rear with the BT010 and BT020.
Old 30-04-08, 11:07 AM   #18
Dangerous Dave
36psi front and rear for the 020's and the 021's, recommended by bridgestone yesterday for both Curvy and Pointy.
Old 30-04-08, 11:08 AM   #19
BillyC
BillyC's Avatar
What a u-turn!
Old 30-04-08, 11:26 AM   #20
Dangerous Dave
Originally Posted by BillyC View Post
What a u-turn!
Well it is Bridgestone!
Had my 1st wobble last night Nobbylad Bikes - Talk & Issues 11 02-10-08 03:39 PM
Head shake/front wheel wobble Nobbylad SV Talk, Tuning & Tweaking 8 17-07-08 07:41 AM
Front end wobble SV andy SV Talk, Tuning & Tweaking 8 26-06-07 07:58 PM
Front wheel wobble wtdafk SV Talk, Tuning & Tweaking 2 09-06-06 09:19 PM
High speed wobble SV1000 retrofly SV Talk, Tuning & Tweaking 9 16-05-06 09:52 PM
