Old 14-05-08, 05:34 PM   #11
stnd
Default Re: Rear Cylinder not Firing
Provjerio sam... Dva puta =)...
Double checked.
Old 14-05-08, 05:45 PM   #12
zadar
using F mark on rear?
Old 14-05-08, 06:00 PM   #13
stnd
yeah F mark with the cams pointing towards eachother as per the manual. 1R pointing to the front of the bike on the intake and the 2 and 3 are 16 links apart. I think if the timing was off I would hear some crunching in there =)...
I'm almost certain it is the rear carb, so when I have a few hours to deal with it I will take them appart and clean them. I'll keep this thread posted.
Old 16-05-08, 03:00 AM   #14
stnd
One of the intake valves broke and the springs were released leaving the valve open. Gonna order a few new parts and take the top of the cylinder to a shop so they can install since I don't have one of those c-clamps to compress the spring.
Either way, glad I finaly found out what the cause was.
Old 16-05-08, 03:04 AM   #15
zadar
valve or retainer.
02's like to break retainers.
you sure cam timing is right?
Old 16-05-08, 03:23 AM   #16
stnd
It the retainer that gave. And since the valve was open it got banged a few times and seems to be stuck in there. I don't want to try and force it out myself not sure if I can damage anything.
Timing was correct, the shim was out of its place when I took the tapet off.
Old 16-05-08, 04:31 AM   #17
zadar
I don't think you can do any more damage
damage is already done.let professionals deal with it.if you lucky head will be fine.
end of valve will need to be ground to get it out through valve guide.
Firing on one cylinder arrrgggghhhhh please help! jimmy-james SV Talk, Tuning & Tweaking 13 06-06-08 11:28 AM
Front cylinder not firing - why? trinyquist Bikes - Talk & Issues 9 17-12-07 07:56 AM
K3 - Intermittent Firing on Rear Cylinder robertwo SV Talk, Tuning & Tweaking 5 04-12-06 05:41 PM
Q) Why isn't my rear cylinder firing? northwind SV Talk, Tuning & Tweaking 3 05-10-04 05:22 PM
rear cylinder dead Nurf Idle Banter 0 07-01-70 02:19 PM
