Old 04-07-08, 01:46 PM   #11
Ceri JC
Default Re: Ground Anchor in wood?
If using the bucket approach, you might want to consider a "trug"; a high capacity gardening bucket like these. There is no way 45 litres of concrete is going anywhere easily!
http://www.gardenxtras.com/productde...y%99+and+Trugs
NB: As it'd be so heavy, I'd only recommend this as more permanent measure as disposing of it afterwards would be a real pig (most likely pick axes/stone cutting angle grinder to cut it into managable chunks).
Old 04-07-08, 02:10 PM   #12
Gazza77
Gazza77's Avatar
I've a sneaking feeling that might fall through the floor.
Formerly Blue K5 with added bits
Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust
Now Benelli Tornado
Gazza77 is offline   Reply With Quote
Old 04-07-08, 02:31 PM   #13
muffles
I am unsure of the weight-to-volume ratio of concrete but mine weighed 50kg after I was done with it...just FYI!
Old 04-07-08, 02:35 PM   #14
Dave The Rave
Alternatively 10 litre bucket filled with mercury. That will also go absolutely nowhere
Old 04-07-08, 02:58 PM   #15
muffles
I prefer dark matter
Old 04-07-08, 04:22 PM   #16
Ceri JC
Surely if it's knocked over, a bucket of mercury will go everywhere?
Old 04-07-08, 06:36 PM   #17
simesb
Or worse, form into the Terminator T-1000 or similar
Old 05-07-08, 01:36 AM   #18
xXBADGERXx
As long as it is on your side and protecting the bike then it`s all good baby
Old 05-07-08, 09:01 AM   #19
scottjames
also depends on what type of wood floor. some times old wood floors are solid and with a coach bolt through em i dont think it would go any where, if we are on about newer floors then probaly the concrete tub idea.
i always found a good alarm helps me keep peace of mind, other than tht i just chain round the rear wheel.
Ground Anchor help mustnt grumble SV Talk, Tuning & Tweaking 12 03-10-08 09:31 PM
which ground anchor? nik_nunez Bikes - Talk & Issues 9 12-07-08 01:43 AM
Ground Anchor kieron Bikes - Talk & Issues 5 06-07-08 01:34 PM
What do you think of my new ground anchor? thor Photos 12 11-05-07 04:31 PM
Ground Anchor mysteryjimbo Bikes - Talk & Issues 16 08-02-05 09:59 PM
