Old 12-07-08, 09:54 AM   #11
Default Re: Serious Gearbox problem :(
IIRC yes, but you can see the assembly with the clutch attatched.
Old 12-07-08, 09:56 AM   #12
silent11
ok thanks
mainly cause i dont have the "special" tool and i havn't got the engine out to lock it in position using a vice
Old 12-07-08, 09:57 AM   #13
Put it in gear and hold brake on
Old 12-07-08, 10:03 AM   #14
silent11
ok kwl thanks allot
Old 12-07-08, 01:04 PM   #15
silent11
right basically got the side off, we managed to get her up and down the gears.
but when in second we have to gently push down on the lever and i springs it self back, which then lets us go up to 3rd gear etc.
does this sound like the rod is bent meaning the selectors are not engaging straight meaning you have to push down slightly to get it in position again?? (if that makes any sense)
Old 12-07-08, 03:10 PM   #16
petevtwin650
Are you sure that the lever isn't just stuck and not returning properly.
I had a similar problem years ago. it was the the fact the the nylon bush in the gearlever which bears on the shaft wasn't lubed and it had to be knocked back down after each gear change.
Old 12-07-08, 03:40 PM   #17
Originally Posted by Me 10 posts earlier View Post
Right start with the simple stuff like is the lever moving freely?
HTH
Old 12-07-08, 04:23 PM   #18
silent11
right ive check the lever etc and nothing no change
basically i can drop it down to 1st then up to 2nd but to go up into 3rd, once ive gone up into 2nd i have to push the lever ever so slightly down and you can hear a little click (as if it resets it self) the i can go up into 4th 5th 6th
so iam not sure what happening its going up and down but why do i have to push down first to go past 2nd gear.
Old 12-07-08, 04:37 PM   #19
thedonal
This is possibly a silly question and you've perhaps already thought of it, but have you checked that the left footpeg with the gear lever on is secure and the hanger is on tight?
After an off and straigtening out the linkage rod last year, I spotted that mine was loose (the footpeg was a little wobbly)- causing just these symptoms- would go up to 2nd, but took an effort to get into third, and then was a nightmare to get back down from there to 1st.
Old 12-07-08, 04:40 PM   #20
silent11
yeah all the hanger etc is secure
Gearbox Richie Stuff Wanted 0 09-07-07 08:09 PM
Gearbox Fix? seandixie SV Talk, Tuning & Tweaking 11 29-06-07 09:32 AM
Gearbox problem??? shortie SV Talk, Tuning & Tweaking 1 14-05-06 02:20 PM
Gearbox Daglad SV Talk, Tuning & Tweaking 12 02-04-06 09:26 PM
Gearbox sprocket. cassius SV Talk, Tuning & Tweaking 6 02-02-05 11:33 PM
