Old 14-07-08, 12:14 AM   #11
jaepres
Default Re: i dropped my sv 650 now it wont start
the red light is on but it doesnt say FI on it. how do u bypass a clutch switch. sorry thanks for the help
Old 14-07-08, 12:24 AM   #12
jaepres
the fi light is on but it doesnt say Fi on it. how do u bypass the clutch
Old 14-07-08, 12:26 AM   #13
ThEGr33k
Im not 100% so i wont say what i think... Sorry. I think Orkie Chris will know since he suggested it
Old 14-07-08, 11:12 AM   #14
Clutch switch, just take the connector off the bottom of the switch and stick a bit of wire between the terminals.
http://sv650.org/sv_faq.htm#Adjustin...02003%20-%20SV
See there for how to put it in dealer mode, that'll tell you if there's a fault code stored. Not sure the light alone indicates a fault, is "chec" displayed?
http://wotid.com/tls/content/view/16/49/
If there is a fault code, that tells you what they mean.
Old 14-07-08, 11:41 AM   #15
Flamin_Squirrel
If you've not got an FI warning, and the red light isn't flashing, it's not the tip over sensor or anything else remotely serious. Kill switch or clutch switch are the likely culprits, providing you're in neutral. If it starts in neutral then dies when you put it in gear then it's the side stand switch.
Old 14-07-08, 12:40 PM   #16
carty
Tenner says it's in gear
Have you got a neutral light on the dash? Have you tried moving the clutch lever up and down a bit (a lot) to see if it's in gear?
I speak from experience......
Ahhh, dropped my SV and now it wont start. edsurf2004 SV Talk, Tuning & Tweaking 12 24-10-08 09:21 AM
sv 650 wont start jaepres SV Talk, Tuning & Tweaking 2 14-07-08 06:35 AM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
sv wont start robbieracer SV Talk, Tuning & Tweaking 4 25-02-07 01:55 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
