Old 10-09-08, 02:58 PM   #11
jambo
jambo's Avatar
Default Re: spark plug pics,lean or OK ?
I know almost nothing about tuning a motor for lean / rich running. However, according to a site I've referenced in the past, Mikuni 152s are not a very big step up from Dynojet 140s:
http://roadstarclinic.com/content/view/61/96/
You may need to go further if you were running more than a very little lean.
HTH
Jambo
Old 10-09-08, 04:15 PM   #12
boo86
i was running this lean
Old 10-09-08, 04:19 PM   #13
boo86
attached this time
Old 10-09-08, 05:54 PM   #14
embee
embee's Avatar
If that graph is to be believed then I'd say you're still too lean. I'd be looking for lambda 0.9 or about 13:1 A/F at the leanest personally for max output.
As for plugs, visually it can be tricky as others have described, and to a large extent it can be a reflection of the plug grade suitability. What grade are you using? If this is a track only use, there'll be little problem in going one grade colder than stock, the only risk is some cold fouling which you can avoid simply be careful start-up procedures, but once up to race speeds it won't be an issue.
Old 11-09-08, 07:53 AM   #15
boo86
Yeah. This graph is from when i was running 140 dynojets. I've now gone up to 152.5 mikunis. It seems to be fueling a lot better but I don't want to spend another £60 to dyno it and find out for sure. The whole idea of racing in minitwins was to keep the cost down. I havn't even got a set of wets !!
spark plug query appollo1 SV Talk, Tuning & Tweaking 3 29-03-09 04:52 PM
Spark Plug Caps HopefullySoon SV Talk, Tuning & Tweaking 1 19-12-07 07:47 PM
Spark Plug Type? The_Noose SV Talk, Tuning & Tweaking 7 23-11-07 12:30 AM
HELP! spark plug problem heedbaw SV Talk, Tuning & Tweaking 7 23-10-07 02:36 PM
spark plug under warranty enzyme SV Talk, Tuning & Tweaking 6 04-03-05 12:50 PM
