Old 15-09-08, 07:49 PM   #11
sv650k4
Default Re: Fuel system problem
Originally Posted by Bluethunder View Post
I mean by that it won't fire up, the battery is fine I know this as optimate charger shows all is good.
How do you clean the carbs?
A ryt just wasnt sure wot you ment when you said that lol.
thers all we bits in the carbs that block up when i do them i normaly use the compressor tho you dont need one 2 do it if you have never done it before i would let someone who nos wot ther doing do it for ya or get a manual as said above.
and as northwide says its not lickly that both carbs would block at the same time so it could maby be something else check that fuel is getting 2 the carbs ok etc...also is ther a spark few the plugs???
Fuel pump problem, maybe. mudgutsdunn SV Talk, Tuning & Tweaking 5 11-03-10 11:54 PM
2002 sv 650 fuel tank problem bravehart SV Talk, Tuning & Tweaking 65 03-03-10 05:54 PM
Fuel System Issue IrishGirl SV Talk, Tuning & Tweaking 4 05-10-07 09:35 AM
Fuel Light Problem Bez SV Talk, Tuning & Tweaking 8 08-05-06 01:04 PM
Fuel Injection problem??? pedrosis SV Talk, Tuning & Tweaking 6 08-06-05 12:21 AM
