Old 02-10-08, 12:47 PM   #11
SoulKiss
SoulKiss's Avatar
Default Re: how long does a res of scottoil last
nope extra tubing is about £3
Which is why I joined the tube - and had no probs
Old 02-10-08, 01:06 PM   #12
About 1k miles.
Old 05-10-08, 10:38 PM   #13
xXBADGERXx
I have the HCR and haven`t topped it up in 6 months , getting a bit low now
Old 05-10-08, 11:01 PM   #14
Lozzo
Mine manages about 800 - 1000 miles, depending on weather. When it rains I up the output another 1 on the dial.
Old 06-10-08, 11:28 AM   #15
admin
John T
admin's Avatar
Originally Posted by Interceptor View Post
On the Curvy, if you remove the nearside (chain-side) seat infill triangle, you will notice 2 small 6mm tapped holes in the frame, I made a small "L" shaped bracket, and mounted mine there, the advantages are you only have to remove the small panel to check & adjust the oiller & it mounts upright !!
I Originally fitted mine there, but the heat from the exhaust thins the oil and it runs out even quicker.
Moved it to here in the end. I could fill it up by removing the rear seat
Old 06-10-08, 08:40 PM   #16
xXBADGERXx
Red Scottoil ? enlighten me
Old 06-10-08, 09:07 PM   #17
Stu
Trinity
Stu's Avatar
Daily use, minimal setting once a week/1000 ,is is about the norm.
Cheers Mark.
You just wanted to show off
Old 07-10-08, 12:19 AM   #18
monkey
but yes you are right, thats where i fitted it to my old curvy
Well then you should know how often to fill it??!!!
Old 07-10-08, 09:25 AM   #19
Stu
Trinity
Stu's Avatar
2 different colours with different viscocity for colder or warmer climates.
Ask someone else which is which I use black oil
Old 07-10-08, 09:25 AM   #20
punyXpress
punyXpress's Avatar
,tis BLOOD!
How Long? Sheila SV Ecosse 33 25-02-07 11:16 AM
What colour scottoil ? oldjack SV Talk, Tuning & Tweaking 7 15-09-06 02:34 AM
My Sunday (long, very very long) svsk2 Bikes - Talk & Issues 29 05-08-06 02:08 PM
So, how long off work is too long?! K Idle Banter 31 23-03-06 09:01 AM
